Old 03-08-2005, 09:03 PM
samh samh is offline
Registered
Rep: 10 Posts: 38
catamaran and trimaran hull form
Can someone provide me with a starting place for designing catamaran and trimaran hulls as far as Cp and LCB? Also the displacement distribution in a trimaran between the amas and vaka (? I think I have the terminology right for the main hull and the floats.)
Old 03-08-2005, 10:11 PM
Skippy Skippy is offline
Rep: 12 Posts: 568
For the tri, it looks like ama size is usually 100-200% of total boat displacement. The main hull of course would be bigger and designed for low wetted surface, planing, cabin space, and other considerations. If you're also asking about actual displacement when in the water, the bottoms of the amas usually sit right at the surface when the boat is dead level, taking zero displacement.
Old 03-08-2005, 10:42 PM
Doug Lord
tri or cat
There can be important considerations based on the size of your boat and the intended use; can you fill in a little more info?
Old 03-08-2005, 11:05 PM
Registered
Rep: 10 Posts: 38
general coefficients of form
I think Larson and Elliason give .54 as a reasonable, general starting Cp for a monohull. I was wondering if there is a same sort of target for catamarans and trimarans? Same with the multihull equivalent of a monohull's lcb of .535.
S
Old 03-08-2005, 11:54 PM
Rep: 12 Posts: 568
I think Cp is usually higher for a multi than a mono, for both better pitch stability and higher speeds. John Teale has for a mono,
V/L ........ Cp
1.15 ...... .55
1.25 ...... .6
1.5 ........ .65
A cat especially should be higher Cp for the same V/L.
Old 03-09-2005, 12:26 AM
Registered
Rep: 10 Posts: 38
Thanks. Also found http://www.tedbrewer.com/yachtdesign.html which illuminated some concepts that I didn't really understand.
S
Old 03-09-2005, 10:43 AM
Rep: 12 Posts: 568
Thanks for that link, it's a good summary. Brewer's book is nice. It really gives you a feel for hull shape, and you don't have to be an expert to read it.
Old 03-09-2005, 12:28 PM
dougfrolich dougfrolich is offline
Rep: 140 Posts: 560
Longitudonal stability is an important concern for multihulls, consider as the apparent wind angle increases, the trimming moment produced from the rig will start to approach the heeling moment in magnitude, if the trimming moment exceeds the heeling moment to early the boat will be suseptible of pitchpole. For trimarans, by placing the LCB of the ama forward of the LCG, trimming moment can be balanced. To figure how far forward; choose the crit AWA and AWS, find the trimming moment divide that by the sailing displacement, the result is the distance forward the LCB should be from the LCG ( at the chosen AWA,AWS ). Any hydrodynamic lift generated fwd of the LCG, from canted foils or bottom shape for example would reduce the distance. So basically it is a ballancing act. For your hull shape just make them as long and narrow you can for your displacement, choose a sectional shape with minimum wetted surface, and include plenty of reserve bouyancy so you dont bury the leeward bow. For more info check out Design of a 40 foot Multihull for Offshore Racing by James Antrim availible thru SNAME.
Old 03-09-2005, 01:22 PM
Ron Cook Ron Cook is offline
Rep: 27 Posts: 66
Cats and Tris
I have alot of experience with both having over 50,000 ocean mile on them.
If a beginer designer makes mistake with design of a monohull it may not be a good boat but if you make mistakes with mulltihulls they will bite you bad.
I don't want to put you off your project. I have participated in the design of a number of mulltihulls and I have built some. it was great rewarding fun.
Be warned that monohulls have nothing in coimmon with mullties. So done use the ratios from one to help design the other it is apples and oranges.
The cp for the average mullti is .60 to .65
mullti's don't suffer in light wind the way monos do with high cp.
On a tri the float should be at 150% or higher with its center of boyancy around 12 1/2% forward of the center of B for for the main hull which is commonly around 56% aft.
Good luck with your project, I love mulltihulls But be warned that if you screw them up they will bite you.
Ron
P.S. Is there aspell checker in this posting system?
Old 03-09-2005, 03:39 PM
DaveB DaveB is offline
Rep: 11 Posts: 128
Hi,
Interesting to hear the numbers... wasn't sure how they'd compare... I'm workin' on a powercat right now with a Cp of 0.63... Lucky I guess...
What do you mean when you say:
Originally Posted by Ron Cook
On a tri the float should be at 150% or higher....
Cheers,
Dave
Old 03-09-2005, 04:52 PM
Rep: 27 Posts: 66
tri float 150%
The float on a tri should be designed to carry 150 % or higher of the total crafts displacement without putting the deck under. The shape of the float on a cruising tri shuold be more v;d then on a racer. The reason is for motion comfort and less pounding which can rattle the the boat inclulding your teeth.
Ron
Catamaran vs Trimaran Maciek188 Multihulls 88 05-31-2009 10:48 PM
Wooden Trimaran Chris Ostlind Boat Design 26 10-29-2005 01:50 AM
Wetted surface area - approximate formulas Mike D Boat Design 11 08-25-2005 12:00 PM
Designing hulls for efficient slow motoring JonathanCole Boat Design 96 06-29-2005 01:55 PM
Wetted surface area II: Cat hulls or Monos? Mike D Boat Design 1 09-26-2002 12:26 AM
