If you want objective comments, you need to post the body plan, profile and also more hard data on the boat. Otherwise all you're asking is for "other people" to agree with your hunches or guesses of what to do. |
| If boat is in alloy, probably it is too heavy and first thing to do is try reduce weight. |
| Thanks for the 2 cents, cavalier! I didn't consider chine vortex shedding as a possible candidate. Thanks ![]() |
| Wigley Hulls Hi Sundancer, you will find a lot of research about Wigley Hulls with Google, mostly academic and very interesting. If you really want to get hulls with optimized hydrodynamics you have to look for the flow of water around your hulls. May be it is helpful for you to get some photos from another boat to analyze the vortices and waves around and under your catamaran. May be I am wrong, but from my experience I would avoid too much gradient of curvature and reduce the wetted surface as much as possible. This can be done by slight hydrodynamic lift from an optimized water flow. |
Thanks and Tschüß |
| Sundancer's drag consistent with research data Thanks to Manfred.Pech's suggestion to Google Wigley hulls, I came across a paper published in Ocean Engineering by Moraes, et. al. in 2004 (vol 31, pp 2253-2282) To my pleasant surprise, they studied the wave drag of chine hull catamarans as well as the Wigley hulls as a function of their separation distances. With the help of the data in this paper, I was able to establish that Sundancer's drag rise behavior is entirely consistent with this class of catamarans, and not something odd. The details follow. Thanks again! Sundancer's hulls fall well within the ranges analyzed except for the block coefficient, since Sundancer's deadrise is 0 degrees (flat bottom). Sundancer has following parameters: L/b = 10.6 b/T ~ 2.5 S/L = 0.32 Entrance/exit = 0.31L Block coefficient = 0.755 Although the focus of the Moraes paper was on high speeds (Fn > 0.3) they did include data points at Fn = 0.2 & 0.3. Of particular interest was the non-dimensional form of the wave drag, C*, given in figures 31,33 & 35, based on the 'Shipflow' 3D analysis code. Albeit a little hard to read accurately, these figures show ~ 45% drag rise in this neighborhood, with only a slight dependence on hull separation distance (S/L). The rise is very significant above 0.3, with a significant dependence on hull separation between Fn = 0.4 and Fn = 0.6. Since Sundancer's low power limits its speed to ~ 0.33, I concentrated on trying to read the Fn = 0.2 & 0.3 data point values as accurately as possible by enlarging the charts. Acknowledging that propeller and motor efficiency vary over the speed range, Sundancer's drag trends can still be roughly inferred from the motor input power, After removing known constant overhead power, I divided out the cubic speed dependency on power (quadratic drag from the definition of a fluid drag coefficient). I then superimposed C* values from the Moraes paper rescaled to my 'funny units', and achieved a very reasonable match as shown in the attached chart. I appreciate all the comments that I've received, and have certainly learned about some improvements that could reduce power consumption at lower speeds if and when another hull is built. However, it is very clear that no great improvements will occur in top speed with < 3kW of motor power. Thanks again to all the contributors for the help. |
| determining CATamaran hull speed | SCATAR | Boat Design | 1 | 03-22-2010 05:00 PM |
| kayak catamaran hull speed? | kayaker50 | Boat Design | 15 | 08-31-2009 08:40 AM |
| Planning hull drag at displacement speed? | steveislucky | Boat Design | 12 | 12-17-2007 05:12 PM |
| Higher speed with drag!! | Verytricky | Stability | 22 | 06-26-2007 10:56 PM |
| Hull speed/drag...theory vs practice? | Bill Fish 6 | Boat Design | 2 | 12-02-2004 10:14 AM |
