| Just to throw a sum into this. If we assume the foil could achieve a lift coefficient of about 1 (which is fairly conservative) at a speed of 20 knots it could provide 5 tonnes of upthrust per sq.m of foil plan area. Since this force is proportional to the square of the speed the high speed of a cat could allow it to make better use of the idea than a monohull. Being able to reduce the freeboard needed would help reduce windage so there could be a performance advantage if the concept was built in at the heart of the design rather than as an afterthought. |
Echoing other comments on this thread... As for weight in the ends of a boat, any boat... NEVER, its a really bad idea. Go for extra length if you have to but keep the ends as light as is possible. |
| There are a number of things one could do to overcome the possibility of the foil producing a downforce or drag through being stalled. If you use a low aspect ratio planform then the foil could be set at a high geometric angle of attack because the low aspect ratio planform reduces the lift slope and making the point at which the foil stalls significantly later. One could also camber the foil so that it had a very early inverted stall which would limit the downforce it could generate if the situation got that far. If you have a look at the ends of the hulls on Dick Newick's "Cheers" you will see 'plates' set up at about 30 degrees and strakes running back down the gunwales from these and this arrangement could be seen as an extreme form of the idea. If one wanted to use a high aspect ratio planform (such as the front crossbeam) as the foil (which would have the advantage of producing a better lift/drag ratio) the foil could be pivoted and sprung in rotation so as to provide some degree of angle of attack self-adjustment which could allow it to feather if the lift force on the foil was negative. |
__________________ Keep smiling Stefano |
| A Cat Hull profile | L. Hutchins | Multihulls | 7 | 01-28-2007 04:46 AM |
| Cat hull design | WildHare | Boat Design | 9 | 01-22-2007 05:33 AM |
| Small Cat with hydrofoil | LHull | Powerboats | 5 | 11-04-2005 04:13 PM |
| Hydrofoil Supported Sailing Cat | Hatchman | Multihulls | 9 | 01-25-2005 08:25 AM |
| stepped hull cat | small cat | Boat Design | 3 | 11-29-2002 05:08 PM |
