Old 07-27-2008, 07:24 PM
Fanie Fanie is offline
Fanie
Rep: 893 Posts: 3,228
Cabin access on a sailing catamaran
Hi guys, I have a simple setup I need to figure out.
On a 10m sailing catamaran, how much water do one get on the aft deck ? And in bad weather ? The reason I'm asking is if the aft deck is higher than the cabin floor (not desirable I know) you don't want water to run into the cabin.
In this case the cabin's bridgedeck clearance is about 800mm and the aft deck is at just over 1m, so a step will have to be added just inside the cabin.
The idea is to use the deck as a beam instead of one big beam doing the job. The deck will then span the boa of the cat.
Just an idea, have to consider all the options.
Regards
Fanie
Old 07-27-2008, 08:27 PM
Banned
Rep: 394 Posts: 2,331
not a lot of water fanie, But at sea anything can and does happen
use a high sill over your doorways, abt 400, to step over
Old 07-27-2008, 10:16 PM
Richard Woods Richard Woods is offline
Woods Designs
Rep: 234 Posts: 189
We never got any water into the cabin on our 10m Eclipse. Even in our "Perfect Storm" we were only pooped twice (more than enough). Eclipse had a cockpit sole that was about 600mm above the WL and an aft beam about 1000mm above the WL.
I don't think you need worry about it.
www.sailingcatamarans.com
Old 07-28-2008, 02:47 AM
Fanie
Thank you very much.
Regards
Fanie
Old 08-03-2008, 05:27 PM
sandy daugherty's Avatar
sandy daugherty sandy daugherty is offline
Rep: 23 Posts: 28
Frog-choking rains can put a lot of water on the aft deck. Add a few 2" drains with a wide grill that will catch all you golf balls and bottle caps and screwdrivers, but still allow a good flow of water.
Old 08-06-2008, 03:01 PM
Nordic Cat's Avatar
Nordic Cat Nordic Cat is offline
Rep: 72 Posts: 164
I have a smallish "drain sump" or recess between my cockpit sole and the saloon. The sump is on the outside of course bu on the same level as the saloon sole. This sump has numerous 1½" drain holes. Size is around 600 mm athwartships and 250 fore/aft.
CE approval requires 5% of the cockpit area as a drain unless you can prove that you can drain it in 5 seconds (I think). I solved this by having an opening at the rear of the cockpit to let water out under the seats.
cheers
Alan
Old 08-06-2008, 04:05 PM
Fanie
Water drainage shouldn't be a problem. I just don't want the odd wave in the cabin. For some strange reason they have a lot more water in them than any other wave
Regards
Fanie
Old 08-06-2008, 04:46 PM
Banned
fanie please take my advice I have done a lot of ocean miles, the sea , it has one quest, and that is to find a way into a boat, and if there is a way it will find that path
Old 08-06-2008, 05:07 PM
Fanie
Think one can confuse that wave if there's more than one way in ?
OK, so what's the real solution ? Seal it air tight then presurise it
I think it's going to be ok. The bridgedeck clearance for the ceck is going to be > 1m the way I have worked it out.
Regards
Fanie
Old 08-06-2008, 05:37 PM
Fanie
Many years ago at an unstoppable age I was once climbing up a high rock that stood out about ten meters or so above the water level. Most of the breakers went far below the spot I had in eye to fish from. It was even shaped kile a comfy chair there with a high thin peak going a few meters higher. The wet line was far below so I figured it safe to get up there.
So, with the last breaker passing I scrambled up there with my fishing rod and some stuff. Beyond the rock was some nice blue water... I can just see the fish I was going to catch, although I had no bloody idea how I was going to get anything substantial up there But I was fishing, and that was what was important.
Now when the fish doesn't bite you buzy yourself with fixing the bait, tidy your rock , look around for... things, you know. Important fisherman chores.
I have a guardian angel. Saved me from many situations. During this buzy phase of fishing I got tapped on the shoulder by this guardian angel I have.
When I looked up, there was this rogue wave right in front of me. It wasn't like anything I have seen before. I also realized that if that wave hit me it was going to knock me off that place and into the rocks ten meters below. It wasn't the kind of thing humans survive. Being mauled by a great white is safer
How long does it take for such a wave to get to a rock a couple of meters furter along ? I dunno. Long enough so you can pack up your stuff, grab the rod and scramble up the peak. The wave passed inches below my feet, foam and huge waters passing around me at a scary speed.
I have no idea what caused that wave. Maybe the incoming and outgoing tide collided , or maybe there was a fish with a bigger guardian angel
Yes, there are waves with a quest. And you have to have a way out.
Regards
Fanie
Old 08-06-2008, 05:46 PM
Fanie
Ok, that's it. I'm fitting stairs to the mast
Regards
Fanie
Old 08-07-2008, 03:43 PM
Splash Gordon Splash Gordon is offline
Rep: 26 Posts: 11
I wanna see you at the Joburg Show next weekend. (And any other Japies with boats, too!)
This project sounds awesome!
Old 08-07-2008, 05:16 PM
Fanie
Eh Splash Gordon... fwd your phone no to my e-mail, I'll call you.
Better have the Splash Gordon suit on eh Are you sure you want to meet these moegoes I have as friends ? I'm not too sure you Capetonians are ready for this yet... like playing Deep Purple or Rammstein in the 1920's
There is this one issue I have to sort out with my guardian angel tho... regarding my ex wife... Oh yeah... and there was this one trip when the fish wasn't biting And now that I think about it there was this time when... He he... I do have one though.
Regards
Fanie
Old 08-07-2008, 05:19 PM
Fanie
He he... Frog choking rains
Regards
Fanie
How to dimension a sailing catamaran? terhohalme Multihulls 79 10-09-2009 01:01 PM
Sailing catamaran parameters terhohalme Multihulls 21 09-28-2009 09:25 AM
Aluminum Catamaran for sailing and cruising searoy Metal Boat Building 4 09-24-2006 02:19 PM
44' Sailing Catamaran Hull fhrussell Boat Molds 3 03-11-2005 09:22 AM
Sailing Catamaran steering Geometry lyndon Boat Design 4 07-24-2004 07:34 PM
