Old 10-06-2008, 11:17 AM
Doug Lord
C Class Cat vs C Class Monofoiler
This is an early(on SA)comparison I did for a C Class cat vs a C Class monofoiler-just W/SA ,SCP/total weight and SA/ws are considered. The monofoiler would have a lower aspect rig than the cat.....(see second post for L/D comparisons):
There are six rules that define a C Class yacht. In essence, they are (with a slight change):
1) It must be a catamaran,trimaran, monohull or any combination thereof.
2) It must have a crew of 2
3) It must not exceed 25’ in length
4) It must not exceed 14’ in beam
5) It may have up to 300 sq feet of sail area (27.90 M^2)
6) It must have a sail number and the class symbol
Just for the hell of it I wanted to see what a monofoiler built to the C Class rules would look like-numbers wise. I included trimarans because this thing would have very small pods-somewhere between 160 and 350 lb. of buoyancy. Just to keep it upright when not sailing-and I wanted it legal w/o an arguement.
C Class Monotri
-LOA 25',hull L/B 18-20/1
-Beam 14' incl. carb racks and pods
-SA-300sq.ft. with a CE just below 75% of a C Class Cat/ Problem: designing it with a high enough lift coeficient at a lower aspect ratio.
- main hull beam 1.25'
- Weight Targets: Hull, foils,racks--120lb
Rig- 140lb
All up boat weight:--------- 260lb
Foil Loading@ 80% on mainfoil: 158lb. per sq.ft.
Mainfoil area: 2.93 sq.ft.(take off profile same as Moth-or better with variable geometry main foil)
Note: to eliminate unecessary flap movement caused by wand averaging in chop manual control of the main foil flap would be tried-no wand)
Rig has to be shorter than the cat version because Monotri RM(including Veal Heel) is only 59% of the cat.
Other comparisons:
W/SA-Cat: 2.26lb (sail loading) Monotri: 1.93lb(sail loading)
Target weight would keep Monotri 100lb lighter than a Cat.
SA/WS ratio flying would be- much better than the cat-in fact only 30% of the cat with the cat flying a hull. And within less than 1% with the foiler off the foils!
Could it be done? Could it win?
If a legit challenge emerged could/would the rules be changed for a trial run that counted?
RM FOR STEVE AND FREDO REFLECTED IN SCP/TOTAL WEIGHT
C Class Monofoiler vs C Class Catamaran--a first look
These are numbers I've come up with that compare a C Class Cat to a C Class Monofoiler:
C Class Cat
A. I found numbers for Invictus: 170kg(374lb) all up ;75kg(165lb) wing, 95kg(210lb) hull,cross beams, foils.
For the purposes of this comparision I reduced Invictus numbers to: 163.63kg(360lb) all up,72.18kg(158.8 lb.) wing,91.44kg(201lb)hull,cross,foils.
Note: on both boats crew CG figured at 1m(3.28') from side of boat(or racks):
Crew weight: 320lb(145.45kg)
B. RIGHTING MOMENT
Measured with boat just flying a hull:
1) CB lee hull to boat CG: 6.5'(1.98m)(assume 1'(.3m) hull beam)=RA; 6.5 X 201=1306.5ft. lb/ 1.98 X 91.44=181.1kg/m
2) CB lee hull to crew CG:6.5'(1.98m)+7'(2.13m)+3.28'(1m)=RA; 16.78' X 320lb=5369.6ft.lb / 5.11m X 145.45kg=743.3kg/m
3) CB lee hull to wing CG: 5.635'(1.71m)=RA; 5.635 X 158.8= 894.83 ft.Lb. /1.72m X 72.18kg=124.2kg/m
4)C Class Cat Total RM:= 7570ft.lb / 1049 kg/m
C.----- Total weight: 320+360=680lb /145.45 kg+163.63=309.08
D. CE at 19'(5.79m)
E.
. Bethwaites Ratio: SCP/Total Weight
1)SCP= RM/ CE-CLR
a.-SCP=7570/19=398.42 // 1049/5.79=181.17
2)SCP/Total weight=398.42/ 680=58.6%// 181.17/309.08=58.6%
3) SCP/Total/WEIGHT(STEVE)=61.7%/color]
4) [color="#4169E1"]SCP/TOTAL WEIGHT(FREDO)=61%
F. W/SA=2.26
W/SA(Steve)= 2.53
W/SA(FREDO)=2.46
C Class Monofoiler
Note: crew =320lb(145.45kg)
A. --- Righting Moment
1) Veal Heel adds 1.5'(.457m) to righting arm
2) crew-1.5'(.457m)+7'(2.13m)+3.28'(1m)=RA; 11.78'X 320=3769.6 ft.lb // 3.587m X 145.45=521.73kg/m
3) hull +foils- 120lb X 1.5'=180ft.lb // 54.55kg X .457m=24.93kg/m
4) wing 140lb X 4.5= 630 ft.lb // 63.63kg X 1.37=87.18kg/m
5)C Class Monofoiler Total RM: 4579ft.lb// 633.84kg/m
B. Total weight=320+260=580lb(263.64kg)
C. CE 13' (3.96m)
D. Bethwaites Ratio-SCP/Total Weight
1)SCP=RM/CE-CLR
a. 4579/13=352.2 // 633.84/3.96=160.06
2)SCP/Total Weight: 352.2/580=60.7%// 160.06/263.64=60.7%
E. W/SA=1.93
NOTE: if the hull weight goes up 50lb(22.7kg) then the ratio changes to 56.8%
This is no guarantee of anything-just very interesting numbers.
Also check this out:
This is the intro to a paper by Alan Smith -who helped get the first two person bi-foil monofoiler in history flying:
Proposed Foil Bourne C Class Cat
Challenger 2007
This presentation puts forward an overview of a proposed new generation of C Class Catamarans. It claims that the fitment of an appropriate foil system will result in a SOFTSAIL(emphasis added) configuration being up to 70% faster than rigid wing non foil fitted competition. Some performance information is provided and comprehensive design files exist that justify the claim. It is in effect a wind powered "air" craft with its lifting and control surfaces in the water. The design process employs state of the art aerodynamic performance,stability and control methods.
The presentation can be found here:
http://www.highspeedsailing.com/sailing.htm Note:as of 10/6/08 this extraordinary site is down-maybe it will come back........
Thanks to Steve for the info................
Old 10-06-2008, 11:37 AM
Doug Lord
Lift drag ratios for a few boats incl. the low aspect foiler rig shown next to a cat below:
Ice Yacht-5.5
Land Yacht-3.8
"Challenger"(Smith design C Class Foiler)-2.8
Cogito-2.0
Int. Moth -1.9
Hydroptere-1.8
(see Alan Smiths site in the first post)
Old 10-06-2008, 12:12 PM
Rep: 593 Posts: 2,054
Could you put up a link that works, please?
Old 10-06-2008, 12:21 PM
Doug Lord
apparently not....
stuck with Cat-Powerboat design (c1 class) in CAD Tjomme Software 1 04-29-2008 12:23 PM
Wing sail for an A Class Cat DSmith Multihulls 36 01-23-2007 06:50 PM
class societies Celine Boat Design 7 04-10-2006 08:35 PM
What class is this boat? Markmif Wooden Boat Building and Restoration 2 02-19-2004 11:51 PM
CommonSense Class Open Discussion: All Things Boats & Boating 1 07-06-2002 07:29 PM
