| BWL and Hull resistance Hi, Is there any formula or graph that relates BWL and Hull resistance? For various Fn ranges? Suppose we keep Length, Displ. and wetted surface constant and we increase the Hull BWL, how is affected the resistance? Thank you Best Regards APP |
For stubbier vessels, there might also be an increase in form drag and from some other non-linear effects, such as the interference between the hullwave and the boundary layer. Good luck! Leo. |
Best Regards APP |
| Catamaran hull waterline beam, depth, and length. Quote:
| Suggestion Dear APP, If you astrict your interest within the limits of Semi-displacement hull definition, the gathered data and the processed results will be strong correlated. I supposed so, that the extracted conclusion should be easier. |
| Freeship gives you access to various tools you can use to assess the drag of various hulls. One that I use is the Kaper module, which was designed to measure drag in canoes and kayaks, and is therefore usable for some multi designs. One approach to increasing displacement that I've used in the tiny cats I've designed is to dispense with the extra chine and use dory-like hulls. For a given length, draft, and fineness, the dory hull will have more displacement than one that uses chines to approximate a semicircular section. Because I feel that the turbulence generated by this approach is less important than the hull fineness obtainable, this is the approach I prefer for very small cats, in which it is difficult to get sufficient displacement. As examples, my 16 foot open beachcruiser Slider has 10 to 1 hulls. My 23 foot voyaging cat will have 11 to 1 hulls. The latter displaces 2200 pounds and draws 11 inches. |
| Stepped Hull Resistance | tkdchris | Boat Design | 6 | 02-13-2012 02:08 AM |
| Hull Resistance | Javaid Hosany | Propulsion | 10 | 04-28-2008 10:55 PM |
| Hull Resistance | ChrisGibbs | Boat Design | 6 | 01-06-2005 04:18 AM |
| Increased Hull resistance? | Powerboats | 13 | 08-22-2002 10:10 PM | |
