Old 12-31-2007, 02:43 PM
terhohalme's Avatar
terhohalme terhohalme is offline
Rep: 478 Posts: 484
Building small cruising catamaran
Hi all,
Started to build a new small family catamaran, Catharsis 26. We cnc-cutted two building jigs for a hull and a deck in two days. Now waiting a huge stack of nidaplast (nidacore) to start the project of two similar catamarans.
Building small cruising catamaran-cnc-router-work.jpg  Building small cruising catamaran-trial-set-up-hull-mold.jpg  Building small cruising catamaran-trial-set-up-deck-mold.jpg
Old 12-31-2007, 06:29 PM
jamez jamez is online now
Rep: 184 Posts: 263
Hi Terho,
I'll be following this with interest. Do you have a website for the build? Also a question. I notice the Catharsis is very similar overall to the BoxCat 26. I notice the Boxcat is a little wider and has more sail, but otherwise is similar indisplacement and layout. Is the Boxcat 26 an easy build version of the Catharsis? If there are other differences between the 2 that are not obvious could you please elaborate?
cheers
Old 12-31-2007, 08:02 PM
JCD JCD is offline
Follow the Bubbles!
Rep: 36 Posts: 359
Originally Posted by jamez View Post
Hi Terho,
cheers
Hello Terho...dido.
Did you cut on your own equipment or is it rented?
J
Old 01-01-2008, 05:29 AM
terhohalme's Avatar
Rep: 478 Posts: 484
Jamez,
New website is under consideration. BoxCat was just a proposal, a spar-buoy by the route, design never completed, boat never built.
JCF,
I'm lucky to work in Omnia Vocational College and I can use cnc of our boat department.
Old 01-08-2008, 02:01 AM
Janez Janez is offline
Contact
Hello terhohalme
I am also interested in this design but i am unable to contact designer trought the e-mail on his web page. Do you now on which mail i can contact him? Thanks.
Lp
J
Old 01-08-2008, 11:28 AM
terhohalme's Avatar
Rep: 478 Posts: 484
Janez, answered you via email.
Old 07-28-2008, 02:21 PM
terhohalme's Avatar
Rep: 478 Posts: 484
Catharsis 26 advance
Hello all,
Redesigned the bows and she grew up to 27 ft... We changed the daggerboards to LAR keels to get more room inside.
Almost all the 160 sheets of nidaplast are now infused by polyester and 0/90 850 g/m2 glass for two catamarans. The longest infusions was more than 9.5 meter long. The sheets are nc-machined, numbered and piled for construction. We have used now some 1100 men hours for two catamaran.
When the college starts in the middle of August, the students will start the construction work.
Terho
Building small cruising catamaran-bulkheads.jpg  Building small cruising catamaran-deck-test.jpg  Building small cruising catamaran-mast-bulkhead.jpg
Building small cruising catamaran-infusion-process.jpg  Building small cruising catamaran-nc-router.jpg  Building small cruising catamaran-hull-sheets.jpg
Only shared knowledge can grow.
Old 07-28-2008, 02:43 PM
terhohalme's Avatar
Rep: 478 Posts: 484
Catharsis 27
Some new models:
Building small cruising catamaran-catharsis-27-accommodation-3.png  Building small cruising catamaran-catharsis-27-sails.png  Building small cruising catamaran-catharsis-27-top.jpg
Cruising Catamaran with Center Board gonewalkabout Boat Design 11 10-01-2007 05:50 AM
Steering Wheel on a Cruising Catamaran b_rodwell Boat Design 10 02-18-2007 09:25 PM
Aluminum Catamaran for sailing and cruising searoy Metal Boat Building 4 09-24-2006 02:19 PM
Cruising Catamaran MrYagci Boat Design 2 04-25-2005 08:22 AM
Square boat cruising catamaran Ozark john Boat Design 5 03-04-2004 08:44 AM
