Old 08-13-2008, 06:14 AM
Rep: 700 Posts: 691
Build your own wheel steering
Hello all
I am in the process of converting my 38 footer from tiller to wheel steering. I don't want to make a composite wheel but I would like to stay away from Edson parts for the axle and sprocket if possible.
Has anyone made their own bulkhead mounted steering system - quadrant, axle, bearings etc? Was it worth it?
cheers
Phil Thompson
Old 08-15-2008, 02:04 AM
waikikin's Avatar
waikikin waikikin is offline
Rep: 596 Posts: 1,026
Phil, I built wheel steering for my Beach marine cat, it had a plastic bearing on the outside set into a machined alu housing, a teardrop shaped stack of ply & a flange bearing on the inside of the ply the through bolts held both bearings through the bulkhead, had about a 25mm shaft & a sprocket on the inside with lashings for tensioning the chain to the spectra cable that acted onto the link bar, was simple & cheap. All the best with it from Jeff.
Old 08-16-2008, 08:34 PM
rob denney rob denney is offline
Rep: 382 Posts: 362
Originally Posted by catsketcher View Post
Hello all
cheers
Phil Thompson
G'day,
All my boats have owner made, mostly composite steering. Works a treat, costs very little, takes a while. There are some pictures at http://www.harryproa.com/building_Vi...ding_Vis_8.htm Any questions, let me know.
regards,
Rob
tiller to steering wheel? kayakn Outboards 7 08-25-2008 04:12 AM
How do I remove my steering wheel? Brylk1830 Metal Boat Building 4 04-20-2008 08:21 PM
Steering Wheel on a Cruising Catamaran b_rodwell Boat Design 10 02-18-2007 08:25 PM
steering wheel removal MilitaryPopo Fiberglass and Composite Boat Building 18 01-08-2006 04:14 AM
Steering Wheel garys Boat Design 9 12-20-2005 01:34 PM
