  #106
Old 10-10-2011, 03:49 PM
oldsailor7's Avatar
oldsailor7 oldsailor7 is offline
Rep: 436 Posts: 2,097
Bruce. The answers to your two questions are Yes and No.
  #107
Old 10-10-2011, 04:03 PM
Sea Stallion Sea Stallion is offline
Rep: 10 Posts: 19
Sea Stallion (that's me) has a set of plans. They are not in great shape. I am only building an ama and doing miscellaneous rotten wood repairs and glassing the deck and cabin top for reinforcement so what I have is fine for my job. Progress is being made.
I'm not really in the plan business but I did go today with my originals and made 2 sets of digital reproductions, one for myself and one for Reuben in WA (can't remember his name on here). Here's what came out:
Sheet 1 - came out in 2 parts for some reason, can be taped together no problem
Sheet 2 - full size main hull frames
Sheet 3 - full size float frames
Sheet 4 - damaged original, only got 1/2 the sheet, can work on improving it if need be
Sheet 5 - float construction
Sheet 6 - mast
Sheet 7 - sail plan
  #108
Old 10-10-2011, 05:17 PM
bruceb bruceb is offline
Rep: 214 Posts: 1,134
Thanks for the reply SS! Great! Just don't let the plans vanish again. As you can see, there is quite a lot of interest, and you are holding the only set to come to light lately. When my local blueprint/copy shop copied my 24 plans, they also made a cd for me with all the info on it, so they can be reprinted anytime. The frame patterns are the most important, almost everything else could be reverse engineered from them. I will happily pay for any part of the plans that you care to copy. Do you have any pics of your re-build progress? I have seen many tris and several Crowthers, but never a 28, but it looks as if it is one of the nicest designs in its size range. B
  #109
Old 10-11-2011, 06:26 PM
lgenova lgenova is offline
Rep: 24 Posts: 46
Good news. I also appreciate having a copy and would be happy to pay for it.
  #110
Old 10-19-2011, 04:47 PM
Bob Hines Bob Hines is offline
Rep: 10 Posts: 9
B 28 Plans
The CD sounds like a great idea Bruce. I would pay for this or a hard copied set of plans. Sounds like this may work for us!
  #111
Old 10-22-2011, 11:35 AM
farjoe farjoe is offline
Rep: 26 Posts: 156
Has there been any progress on this issue? For me a downloadable copy would do.
regards
  #112
Old 10-24-2011, 05:22 AM
oldsailor7's Avatar
Originally Posted by farjoe View Post
Has there been any progress on this issue? For me a downloadable copy would do. regards
Sorry farjoe. No progress. There seems to be a bit of a stalemate going on. Several people have several bits of it but just don't want to share them.
If I could get my hands on an original set of plans, even if it meant restoring them, as I did with the B24, I would make them available to everybody at a price which would cover my costs ---like the very successful B24 plans package which contained very much more than just the 6 sheets of plans alone.
  #113
Old 10-24-2011, 06:10 AM
Rep: 26 Posts: 156
I may be happy with what Sea Stallion has got.
  #114
Old 10-25-2011, 08:23 AM
Rep: 10 Posts: 9
B 28 Plans
I agree farjoe - if we could get just the 7 sheets through Sea Stallion we would be off to the races!
  #115
Old 10-25-2011, 06:06 PM
plans
I have seen some of the pdf plans- and it would be really hard to build a boat from them. They are not complete, and they were copied from plans that had been used to build a boat- many years ago. They were on very fragile paper if they are like my 24 plans and would have to be restored and then copied, probably a lot of hand drawing would be necessary.
They are interesting, but maybe not in a good way Compared to several more modern designs, I don't think (IMO!) the 28 would be worth building in today's market- there are just better boats available, with designer support. Material costs, even on a tight budget, would be over 20k US, before 2000+ hours labor. Here in the USA, a nice used Corsair-27, well equipped, sells for around 30K, and has more interior, folds, is built of glass, and probably sails almost as well. I would still consider purchasing a 28 if the price was right, but building a new one just does not make much sense. While the 24 is a "quick build" simple boat, the 28 is much more complex design, with no one to ask about design issues or changes. I feel sure it is a fast, nice sailing boat, but it has a really minimal interior for a 28, and the basic structure limits many changes. I think its time may be passed. B
  #116
Old 10-25-2011, 10:52 PM
redreuben redreuben is offline
redreuben
Rep: 349 Posts: 1,468
Farjoe and Bob,
SS has sent me jpgs of his plans but when printed much of the text is unreadable, so no you won't be happy !
SS is looking into getting "professional" copies made at my expense so what comes of that remains to be seen.
Please be patient SS has a business to run as well as a boat to rebuild. You will be kept informed of progress via the forum here so just chill !
RR
  #117
Old 10-26-2011, 09:07 AM
Rep: 26 Posts: 156
@Redreuben,
Thank you and SS for any eventual info you may be able to deliver about these plans.
@Bruceb,
One does not necessarily need more than 7 pages in order to have a good set of plans. I have actually build a multihull of a similar size from a plan set of 5 although I must admit that the designer was available to answer some questions. Previous experience may actually be sufficient to fill in any missing gaps that these 7 sheets may have.
Also please do not assume that everyone wanting a set of plans such as these has the intent of actually building it as is or indeed that cost effective second hand boats are available everywhere.
Regards
  #118
Old 10-26-2011, 09:51 PM
less paper
Farjoe, Sorry, that didn't come across correctly. Parts of the plans are not there at all, they didn't get copied or were too damaged. An experienced builder could build the boat, and with some changes, might even build a better, more modern tri- just using the 28 as a starting point. I have a B-24 that I like very well, but like many boat owners, would like a little larger, more capable boat, and the 28 would be one of my first choices, but in the US, building one new would not be a good investment in time or money since we have so many well priced used boats of all types. Other parts of the world may not be as lucky? as we are. Of course, it works both ways- buying or building a new boat is a quick way to lose most of our investment to depreciation I do hope the the complete plans become available. I have my original ones for my 24 and I purchased a fresh set from OS7 to help in rebuilding my boat, and they are very useful. If I find a good 28, or any other wooden boat, I would certainly want a set of plans. B
  #119
Old 10-26-2011, 11:21 PM
redreuben
In my post above on the plans I said i had jpegs ! Oops pdf's
RR
  #120
Old 10-27-2011, 07:00 PM
Rep: 10 Posts: 9
B 28 Plans
If the "professional" copies become available to you from SS please contact me redreuben. I will pay you for a set of copies. Thanks so much. Bob
Hedley Nicol Trimaran Plans oldsailor7 Multihulls 456 01-17-2017
07:29 AM
Buccaneer 24 Trimaran Samnz Multihulls 573 09-08-2015
12:37 PM
RE: A look-for trimaran plans Liturl_Ellyrod Multihulls 8 02-05-2010
11:43 PM
Farrier Trimaran Plans - F-9A or F-32 PedalPaddlePole Marketplace 3 01-18-2007
05:37 PM
Trimaran Construction Plans PedalPaddlePole Marketplace 0 11-03-2006
09:35 PM
Powered by: vBulletin Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
Web Site Design and Content Copyright ©1999 - 2017 Boat Design Net
