  #61
Old 12-19-2008, 05:10 AM
oldsailor7 oldsailor7 is offline
Rep: 253 Posts: 1,061
Originally Posted by bruceb View Post
My boat sails quite well with one reef in the main, which is pretty close to the stock sail area. I would want a light overlapping jib for light conditions. I use a self-tacking jib for day sailing, it allows the boat to be managed with one hand in most conditions. Bruce
Bruce.
That pic is very good because it highlights the main bulkhead and shows how Lock arranged the stress paths from the rig, crossarms, centreboard case and (not visible) the water stays, to all come together in the strongest part of the boat, the #4 frame assembly.
I'm not sure I like the "kink" in your crossarms though. You need to replace the joiner plug with a better fitting one. Preferably a close fitting piece of 6061T6 pipe, as in the Buccaneer 28.
On my B.24 we used the wooden plug wrapped in f/glass cloth wetted out with polyester resin. Boatbuilding epoxy as we know it now was not available then. The wood swelled as moisture got in and jammed up the sliding tubes pretty tight. Lubricating with automotive grease helped, but it was a bother when de -mounting for trailering. Metal tubing was a better solution.
If your crossarms were straight you would not need so much tension in your forward waterstays.
  #62
Old 12-19-2008, 09:43 AM
bruceb bruceb is offline
Rep: 153 Posts: 564
Inprovments
Thanks for looking. I suspected the "droop" was not correct, but I did not have anything to compare it to. The wood plugs are loose and the outer arms move some under load. (several inches at the outer end) Sort of feels like an old Hobie 16 I like Capricorn's solid beams, but for my use I still have to dismount or fold the floats. The fit seems to be a fine line between eliminating movement and getting stuck. I have been sort of suprised at the plugs taking the fore and aft loading as well as they do. If I don't do anything else, I will get some 6061 pipe before I re-assemble it.
  #63
Old 12-19-2008, 04:18 PM
Yes Bruce,
In that frontal photo you can clearly see the difference in "Dihedral' between the front and back crossarms.
Restoring the angle will also lift the bows of the floats some, reducing the drag to some extent, when sailing in light airs.
  #64
Old 12-20-2008, 12:23 AM
Samnz Samnz is offline
Rep: 42 Posts: 187
Originally Posted by Kalona View Post
Here is a picture of my Buccaneer 24.
Hey Thanks for posting the picture!
Its a very nice looking Bucc. Do you know what the story is with the cabin bunk tops being lowered? I have thought about doing this so many times to give a bit more space in the cabin!
On my boat I have slats the fit accross the space between the two bunks to make it into a double bed, only problem is then there is nothing downstairs but a bed, but we cook in the cockpit with a boom tent anyway.
  #65
Old 12-20-2008, 10:02 AM
Rep: 153 Posts: 564
Cabin mods
I am interested in your cabin also. I really would like to re-install a cabin on mine and my local rating group may require it. Right now I am getting by calling the forepeak a cabin Bruce
  #66
Old 12-20-2008, 05:20 PM
Rep: 42 Posts: 187
Anyone know anything about this one? It looks pretty highly modified and very quick... I got the photo of the net but couldnt find any info on the boat.
  #67
Old 12-20-2008, 06:24 PM
Rep: 153 Posts: 564
Mystery ship
I think the spire/tower in the background is in Seattle, Washington (state) US. Anybody from the west coast on here? Bruce
  #68
Old 12-20-2008, 08:49 PM
Thats one hot looking boat, and I really like the rig.
Is it a trick of the light, or is it possible that one has round bilge hulls. ??
  #69
Old 12-20-2008, 09:33 PM
Rep: 42 Posts: 187
I dont think its a trick of the light, I think it does have round bilges!
Wouldnt be very difficult to do with some foam blocks, and would add a lot of volume. The transom has also been modified, like Mirandas but a hollow scoop.
  #70
Old 12-21-2008, 11:14 AM
Rep: 153 Posts: 564
Round bilges
The floats certainly look rounded, I can't quite tell on the main hull but the transom is extended at least a foot with an inboard rudder. It also looks like a small open cuddy cabin. I am going to search sailing club listings in the Seattle area and see if it shows up. Bruce
  #71
Old 12-22-2008, 09:26 PM
Rep: 153 Posts: 564
Geography lesson
Correction- That is Toronto in the background of your picture samnz. I wonder if it is one of the original four 24's that were built there. (mine is one of them) I have been searching their sailing clubs but no luck so far. Was there any date with the pic posting? Bruce
  #72
Old 12-23-2008, 01:31 AM
The mystery deepens.
That B24s sail #12 denotes the plan was sold in early 1970, or 1969 even.
My B24 was sail#63 and was built in mid 1971.
The CN tower was not completed until 1974-5
Judging by the super modern rig, sugar scoop etc:- I would say that boat is a total renovation ---like Miranda.
  #73
Old 12-23-2008, 01:32 AM
Rep: 42 Posts: 187
No nothing at all, I found the picture many years ago when I was rebuilding mine, trying to find information on the design, I didnt even know what design my boat was when I bought it!
  #74
Old 12-23-2008, 02:52 AM
FOUND IT. It belongs to a sailor in the Toronto Multihull Cruising Club.
Boat Name: Toy
Skipper:
Design: Crowther Buccaneer 24 (modified)
LOA: 25'
I'll try and find out who the skipper is and get more information.
  #75
Old 12-23-2008, 09:18 AM
lutes1234 lutes1234 is offline
Rep: 10 Posts: 8
24' Buccaneer Trimaran - plans
Hello,
I new to this forum, I am a Canadian living on the east coast. I own a 1982 24' Buccaneer Trimaran and currently it needs some TLC (cracking along amas seems and paint). We just had a blizzard of snow yesterday, so sailing is in my dreams and my tractor with a plow is reality right now.
I was looking at another post for plans and oldsailor7 you mention that you had plans, do you still have them for purchase?
My boat, I bought 3 years ago and the previous owner did some modification (made it more comfortable but lessen the overal performance) and has written some articles for the Multihull Magizine. So, I am inspired by you all to gain back some of that performance.
Here are some pics.
Thanks,
Duane
22 - 24 trimaran waynemarlow Multihulls 225 02-09-2012 10:14 PM
24 ft trimaran Chris01 Multihulls 17 08-21-2010 07:55 AM
Need help ,trimaran petee Boat Design 3 08-19-2005 11:11 AM
trimaran Lem Multihulls 5 04-08-2005 04:48 PM
looking for a 21 ft trimaran arzpengwen Boat Design 3 09-13-2004 10:01 AM
