  #181
Old 04-28-2009, 07:22 PM
bruceb bruceb is offline
Rep: 153 Posts: 564
crossbeams
Thanks, the 28's tubes are about an inch larger than the 24's, and a little shorter. My 24 uses 3/8 bolts also, so I guess they are a bit over done, though anything smaller tends to strip so easily I would not trust them. The 28 appears to be about twice the size of the 24- a whole lot more boat. Bruce
  #182
Old 04-28-2009, 11:50 PM
oldsailor7 oldsailor7 is offline
Rep: 253 Posts: 1,067
Yes.
I built two Buccaneer 28's---one for myself.
It was a great boat. We used to cruise it with four people and in twenty four races over a two year period it took 21 firsts 2 thirds and a 2nd place, racing on Lake Ontario. It was the best Trimaran I have ever owned.
Unfortunately I was stupid enough to let the plans go when I sold it.
  #183
Old 04-29-2009, 02:34 AM
Samnz Samnz is offline
Rep: 42 Posts: 187
Originally Posted by oldsailor7 View Post
Yes.
did you ever race against an equally well setup and sailed 24? if so how did they compare % wise? Do you know the dry weight (no sails or crew)?
  #184
Old 04-29-2009, 07:37 AM
Sea Stallion Sea Stallion is offline
Rep: 10 Posts: 11
Yes.
My boat originally came from Ontario but was built somewhere around Bay City, MI I believe and in the early '80s. The plans came with my boat. It also had a composite wing mast and sail that were formerly on Adagio. Same boat?
  #185
Old 04-29-2009, 12:55 PM
Rep: 153 Posts: 564
28 cost
Oldsailor, How did construction time and cost compare between the 24 and 28? Bruce
  #186
Old 04-30-2009, 03:47 AM
Yes. Another member of our club built one in parallel with me. Took him a bit longer though. Two boats were identical except I had my Jib sheet angles narrower and a bigger vertical daggerboard. As a result I could always beat him on the windward leg. Cannot remember the weight. After all it was 36years ago.
  #187
Old 05-01-2009, 02:40 AM
Rep: 42 Posts: 187
Sorry I meant race your 28 against a 24? or anyone ever raced a bucc 24 vs a bucc 28 with equal sails and crew skills?
  #188
Old 05-01-2009, 02:44 AM
I guess the answers NO.
  #189
Old 05-18-2009, 07:52 AM
Rep: 660 Posts: 664
Anyone near Newcastle?
I met a bloke with a Bucc 24 that needs a lot of work. If I were to get it I would cut the cabin off and just go day racer with it. It has sails and a rig but you need to be near here to get it. The guy is a nice guy who doesn't want it to die. He seems ready to let it go if someone will do the work. The boat is out of the water at the mo.
If anyone near Newcastle NSW feels this could be them get back to me.
cheers
Phil Thompson
  #190
Old 05-19-2009, 03:04 AM
zigzag zigzag is offline
Rep: 10 Posts: 47
buc 24 Newcastle
Hi I am Interested in that buc 24 can you send contact no? Also I have buc 28 plans if anyone needs them
  #191
Old 05-19-2009, 03:11 AM
Rep: 10 Posts: 47
buc 28
Does the buc 28 have the same minor design problems as the 24? That is it would benefit from the same tweaking that has proven to be effective on the 24's. Personally I think the 33 is the most elegant of the Buc series. No hope it seems of getting plans on that model though. I wish there was an enterprising Naval Architect who would draw up some inspired hybrid designs based on these boats. My cheque is in the mail.
  #192
Old 05-19-2009, 05:14 PM
Rep: 660 Posts: 664
Newcastle Bucc
Zigzag
You would have to be able to chop up the boat - it has fixed composite beams. The guy really wants to be able to see it go sailing so I would say Hong Kong is too far. Also it does require a fair bit of work.
  #193
Old 05-21-2009, 09:19 PM
stancil stancil is offline
Rep: 10 Posts: 4
buc 28
zig zag
I'm interested in the buc 28 plans. Talk to me. I'd send you a pm but have to post more first.
I'm looking to build a tri in the 28 to 34 foot range. I like the crowther lines and the ply construction.
  #194
Old 05-23-2009, 04:05 AM
gpb gpb is offline
Rep: 10 Posts: 15
I'm seriously thinking to buy a set of plans. However, I'm not sure that I understood which are the suggested modifications to improve the design... Anyone cares to list them? Thx!
  #195
Old 05-23-2009, 07:30 AM
Rep: 10 Posts: 47
buc plans
In reference to buc plans and modifications. I assume that the tweaking may be applied to the 24 and 28, Oldsailor has much experience and note also the mods to the buc 24 Miranda in NZ,ref 23/11/08 posting. Read through the buc 24 postings and previously the 24' trimarans postings. Oldsailor advocates extending the floats forward
Miranda has an extended stern, and mods to the rudder /centreboard are suggested. Seems a lot of time has passed and many boats have been built that these comments are highly valid. In the finish however one would have a very fast tri. I have also heard the buc33 had a tendency to pitch so perhaps a modification of the stern goes for all. Perhaps we could get Oldsailor to put it all on a drawing for a cost of course.
22 - 24 trimaran waynemarlow Multihulls 225 02-09-2012 10:14 PM
24 ft trimaran Chris01 Multihulls 17 08-21-2010 07:55 AM
Need help ,trimaran petee Boat Design 3 08-19-2005 11:11 AM
trimaran Lem Multihulls 5 04-08-2005 04:48 PM
looking for a 21 ft trimaran arzpengwen Boat Design 3 09-13-2004 10:01 AM
