  #76
Old 08-26-2009, 08:31 PM
bruceb bruceb is offline
Rep: 214 Posts: 1,130
speed
Our faster F24s haven't been out since I put my buc back in the water. Our best sailing season is just starting, I hope I am able to sail to the boat's potential. Bruce
  #77
Old 09-06-2009, 11:16 AM
mast section
I measured my mast section- Aprox 6.25" x 3.7" "teardrop" shape. The base, mast and masthead are stock Stiletto-27 cat parts that rotate on a 2" ball. My mast is 36' overall with the forestay/shroud tang about 6.5' from the top. It has diamond stays and spreaders. I don't know the the section weight but the whole mast, halyards and 3/16" shrouds (wire) weighs around 80 lbs. The mast is quite stiff, probably more than would be required if built to the stock Buc 24 specs. I think the 3/16" shrouds (stock buc 24 size) are marginal for the mast and sail area I have and the closed barrel 5/16" turnbuckles are definitely not up to the job- I will replace it all this winter. I don't have running backstays but will probably add them for the large reacher and some redundancy. Bruce
  #78
Old 09-06-2009, 01:37 PM
Oceannavagator's Avatar
Oceannavagator Oceannavagator is offline
Rep: 15 Posts: 28
Thank's for the information Bruce. It looks as if you have approximately the same weight per foot as the stock design does.
I know that this thread is about the Buccaneer 24 but after the discussions about ama's being driven under I thought I would send this picture that I ran across showing just how far that can go. Supposedly the boat recovered from this and continued the race. I can imagine the crew needed a couple of stiff drinks to recover themselves.
If you're not living on the edge you're taking up too much room.
  #79
Old 09-06-2009, 03:13 PM
Tom.151's Avatar
Tom.151 Tom.151 is offline
Rep: 38 Posts: 177
Originally Posted by bruceb View Post
My mast is 36' overall with the forestay/shroud tang about 6.5' from the top. It has diamond stays and spreaders. I don't know the the section weight but the whole mast, halyards and 3/16" shrouds (wire) weighs around 80 lbs. I will replace it all this winter. I don't have running backstays but will probably add them for the large reacher and some redundancy. Bruce
bruceb,
here's some great info in synthetic shrouds, etc. I converted my Twiggy to SK-75 and lost a ton of weight in the rig. jmolin's rerig of his Searunner shows lots of other ways to replace metal with synthetics. I really like the soft hanks and soft halyard shackles.
Here...
http://forums.sailinganarchy.com/ind...howtopic=95600
and
http://s30.photobucket.com/albums/c3...ner/?start=all
Hope to see your Buc 24 one day,
TomH
  #80
Old 09-06-2009, 10:07 PM
synthetic
I agree, I think synthetic is the way to go, it has reached the stage of development and price that it belongs on many boats, including most all multis. I know I will use it for my runners, and I might use it for my shrouds. I do have a lot of wire that I hope someone can use, and a couple of roll swedge machines to go with it Bruce
  #81
Old 09-12-2009, 10:23 PM
oldsailor7's Avatar
oldsailor7 oldsailor7 is offline
Rep: 436 Posts: 2,094
I still have one set of Buccaneer 24 plans available is anyone is interested.
  #82
Old 09-14-2009, 09:29 PM
shrouds
I weighed my 30' shrouds- 3/16 with an eye and a stud- 2.5lbs each plus the 1/2 lb turnbuckle. I think I am going to use stainless again, the weight saving and price seem to favor wire. (I have plenty of wire) The cost/benefit might be better in a few more years, right now, synthetic still has durability issues, particularly in small sizes. Bruce
  #83
Old 09-20-2009, 06:52 PM
Samnz Samnz is offline
Rep: 47 Posts: 235
do you think 3/16 wire is strong enough? I have 1/4 inch wire on my forestay and sidestays, 3/16 on the topmasts, and 3/16 dynex on the mast head runners. 5mm on the diamond stays. I dont know what 5mm is in metric, in between 3/16 and 1/4...
if you sail with all crew on windward float the loads skyrocket on the rig, im not sure Crowther invisioned this!
  #84
Old 09-20-2009, 11:03 PM
oldsailor7's Avatar
Originally Posted by Samnz View Post
...if you sail with all crew on windward float the loads skyrocket on the rig, im not sure Crowther invisioned this!
I'm sure he didn't either.
In the 1960s and '70s, NO ONE envisioned taller masts, fathead mylar mains, "prodders" with huge foresails and reaching spinnakers.
The huge sail areas you use on yor B24 would have blown Lockies mind.
(Come to think of it, we had mylar sails on our Piver Nugget in 1964. Fad didn't last tho'). LOL.
  #85
Old 09-21-2009, 09:40 AM
big wire
Samnz, I think you have the right size wire- 3/16 has a min breaking load of about 3700 lbs and a much lower working load- probably fine on the stock boat. I haven't been loading my boat up this season but I had better plan for the future and use the 1/4" wire. Do you have two sets of shrouds? ( uppers? "3/16" topmast") - I only have one set of shrouds, and diamonds on the mast. I am set up for runners but I haven't installed them yet. Thanks for reading my post, it might help keep my mast "up". Bruce
  #86
Old 09-22-2009, 05:40 AM
Rep: 47 Posts: 235
Uh yes I have a lot of stays on Capricorn since its rig number 3....
you can kind of see them all in this pic...
Topmast sidestays and topmast runners, plus the sidestays, and doubled up diamonds........
  #87
Old 09-22-2009, 05:43 AM
Rep: 47 Posts: 235
I have argued with many people about this, and still think only higher righting moment can add load to a boat, not more sail area. More sail area just gets the the maximum load quicker, more righting moment actually adds to the maximum load on the rig and hulls/ beams?
More righting moment gained by positioning crew and helmsman on the floats...
  #88
Old 09-22-2009, 09:04 AM
rig load
Samnz, That is a good picture That looks like about a 1000 lbs (no offense to your friends) and you still have some reserve. I think you are correct, the righting moment does limit the rig loads, but with the speed tri's can hit, shock loads and momentary gust loading can probably double the rig loads. I think my mast section is stiffer than yours, I don't know if that is good or bad. It doesn't go out of column as easily, but it doesn't de-power as quickly either. How do you adjust your side stays? Bruce
  #89
Old 09-23-2009, 08:24 PM
LucD LucD is offline
Rep: 49 Posts: 45
B24 photo?
Do anyone has detailed photo of the inside and outside of a B24?
  #90
Old 09-27-2009, 08:19 AM
SteveMellet SteveMellet is offline
Rep: 88 Posts: 196
Plans for Buccaneer 24
I`m interested. Please PM me or e-mail me at stevemellet(at)gmail.com
Buccaneer 24 Trimaran Samnz Multihulls 573 09-08-2015
12:37 PM
Restoring Crowther Buccaneer 33 - Rigging Advice SteveMc Multihulls 23 09-07-2010
09:32 PM
K24T versus Buccaneer 24 gpb Multihulls 70 07-28-2010
05:36 AM
Kitset Boat Builders -Professional Boat Builders Please, eastcape Services & Employment 0 03-24-2009
04:43 PM
How to delete files in your gallery, forum rep points, forum attachment sizes MikeJohns Forum Questions and Suggestions 10 08-18-2007
06:28 PM
Powered by: vBulletin Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
Web Site Design and Content Copyright ©1999 - 2017 Boat Design Net
