  #766
Old 03-27-2011, 11:23 PM
oldsailor7 oldsailor7 is online now
Rep: 269 Posts: 1,118
That definitely looks like a "Stretched" B24.
Lock may have done a custom mod for it, as I know for certain that Lock never designed a stock B26.
  #767
Old 03-27-2011, 11:49 PM
Angélique's Avatar
Angélique Angélique is offline
aka Angel (only by name)
Rep: 1020 Posts: 585
The ad says ‘‘professionally designed and built’’ and it both looks just like that
I'll PM you and Bruce the personal data of the vendor so you can ask him about the design and build history and the availibility of the mod specs if you like...
Good luck!
Angel
PS - But maybe the new owner, B26Trimaran, has that info already..?? If so, please let us know
  #768
Old 03-28-2011, 09:15 PM
B26Trimaran's Avatar
B26Trimaran B26Trimaran is offline
Rep: 10 Posts: 8
First time posting
Greetings from the new owner of the Florida B26 my name is Harold. The B26 was driven from San Diego, Calf. to South Florida. The sellers dad gave it to him as a gift. He is a liveaboard on a much larger Tri and is a good friend. I will pick it up next month ASAP! Please post any questions that you have and I will ask him. I do know his dad sailed alot and had something to do with the aircraft industry.
I have enjoyed reading ALL of the posts about the B24 and look forward to sailing it ASAP!
  #769
Old 03-28-2011, 09:18 PM
Rep: 10 Posts: 8
Good luck!
Angel
I will call him and ask if he has any more info.
  #770
Old 03-28-2011, 11:11 PM
Rep: 10 Posts: 8
Boom canvas tent design drawing
Does anyone have a design for a canvas tent that uses the boom?
Like the one pictured.
http://www.boatdesign.net/forums/att...r-2007-149.jpg
  #771
Old 03-29-2011, 06:08 AM
Just use a suitable sized rectangle of waterproof canvas, with eyelets set in the corners and the centre edges of the sides. Centre it on the boom and tie it off to the shrouds etc:. You can get better support with battens, laid across the boom. Light bamboo poles work well.
Your local sail loft can run one up for you for a few bucks.
  #772
Old 03-29-2011, 07:48 AM
Rep: 10 Posts: 8
Thanks I have a good sailing friend that does canvas work on the side, who will have some customized work to do for me next month.
  #773
Old 03-29-2011, 09:13 AM
bruceb bruceb is offline
Rep: 153 Posts: 565
sun shade
I have one, but have not had much success using it. The cover will shade some of the cockpit, but nobody wants to stay in the cockpit at anchor, and I have had trouble "chasing" the sun. Any breeze at all and the shade works as a sail, and with a boat as light as the Buc, it moves around a lot. I didn't use mine last year at all, and took it off the boat. I think mine is about 8'x12', maybe a larger one would work better, but the poles would get hard to deal with. I do have a "Chesapeake" style main cover that unfolds to cover the cockpit. (like a regular boom tent) It works pretty well and the doubled fabric helps protect the main better when furled. I also have a light bimini that I use a lot, it weighs less than 10 lbs total and is very quick to set up or remove. My crew love it. B
  #774
Old 03-29-2011, 10:40 AM
Rep: 10 Posts: 8
Bimini
Bruce do you have any pictures of the Bimini up and were do you store it when when not in use while sailing?
  #775
Old 03-29-2011, 05:39 PM
Rep: 153 Posts: 565
bimini
I don't have any pics. I fold it to the rear, just in front of the traveler, or store it on one of the tramps. B
  #776
Old 04-15-2011, 08:35 AM
Rep: 10 Posts: 8
B26 is now in Georgia! Pulled like it wasn't even behind the Suburban.
  #777
Old 04-15-2011, 09:25 AM
dstgean dstgean is offline
Rep: 68 Posts: 136
Check out Jim Brown's setup for some inspiration. He's got some videos of Scrimshaw up on youtube that show his details.
Dan
  #778
Old 04-17-2011, 06:15 AM
diegokid diegokid is offline
Rep: 20 Posts: 92
angles
I've got a few more questions after looking at the 24 plans more. When turning the center plug it shows it being cut at 4 3/4 degrees then rotating until maximum angle is achieved, then bolting it together.
1. How high out of the water is the ama when sailing and while at rest. Wanting to know how much of a rocking motion is here. If it is more than a few inches could the angle be reduced by 1/2 to 1 1/2 degree to lower this?
2. Seems like I've read a few posts where the longest time spent from trailer to water/water to trailer is lacing the nets. I'm new to sailing but why couldn't you put some type of mast track on the crossbeams with a simple cleat or three on the amas. When rigging just slide the nets over to the hull and tie off with velcro.
Thats all for today!
  #779
Old 04-17-2011, 07:01 AM
1. When sitting in the water at rest the bottoms of the floats barely touch the water. If the waves at anchor are rocking the boat weigh down one hull with, for instance, a sail in it's sailbag, lashed with a shockcord in the side tramp/net. No big problem really.
2. When sailing, the windward hull is usually high enough to avoid being slapped by waves.
3. Don't change the dihedral, this is not a Piver.
  #780
Old 04-17-2011, 08:03 AM
Rep: 20 Posts: 92
part timers
I forgot one.
The donor boat I located for the mast and hardware will have more than I need. The rigging will be too long and most of the ends on the cables are somewhat rusty and would have to be cut and refitted anyway. Mast is four feet too long being 34'.
Have noticed the colligo rigging on other boats. One of the F boats I looked at had it. They claim its a lot easier to handle/stow when trailering and of course lighter. Cost may be prihibitive since I haven't looked at pricing for a buc but some of you out there may be more knowlegable on this.
Buccaneer 24 Trimaran Samnz Multihulls 377 04-19-2012 08:31 AM
Restoring Crowther Buccaneer 33 - Rigging Advice SteveMc Multihulls 23 09-07-2010 09:32 PM
K24T versus Buccaneer 24 gpb Multihulls 70 07-28-2010 05:36 AM
Kitset Boat Builders -Professional Boat Builders Please, eastcape Services & Employment 0 03-24-2009 04:43 PM
How to delete files in your gallery, forum rep points, forum attachment sizes MikeJohns Forum Questions and Suggestions 10 08-18-2007 06:28 PM
