Old 01-24-2007, 03:59 AM
joeysranger1 joeysranger1 is offline
Big Steel Tri
I am thinking about building a 60-80 ft tri. will be sailing in high latitudes. was wondering if steel hull and aluminium supersturcure would work? do not intend to win races, just wont low heel floating home that can go to out of the way places. any responce would be greatly appreaciated..
thank you
Old 01-24-2007, 08:26 AM
Eric Sponberg's Avatar
Rep: 2547 Posts: 1,426
Joeysranger1,
The technology is certainly there. My Moloka'i Strait motoryachts are steel hulls with aluminum superstructures. For a sailing tri, you simply have to be careful with weights of the materials that you are using and figure that into the design set-up so that the boat floats where it is supposed to at a projected reasonable displacement. Give it the sail area that it needs for the weight. It can certainly be done.
Eric
Eric W. Sponberg
Naval Architect
Sponberg Yacht Design Inc.
St. Augustine, Florida
www.sponbergyachtdesign.com
Old 03-02-2007, 03:28 PM
la cage la cage is offline
Rep: 10 Posts: 17
You may wish to consider my method of construction.
www.bourneboats.com.au
If you type it in the address bar at the top it will come up, Iam not as yet on the google system.
Alternative method of boat building!!!!
Old 03-11-2007, 03:32 AM
Rep: 10 Posts: 17
I have developed a steel sandwich method of construction that would compete with the weight of aluminium. The method is for multichine shapes only. Not necessary to make individual frames, also the dreaded fairing eliminated.
Tri-ing? Yes very! Dodgey_rog Multihulls 34 11-05-2006 11:48 PM
Tri performace MMulti Multihulls 15 09-02-2006 05:11 PM
tri-hull or v with sponsons? flyguy Powerboats 3 06-07-2006 12:18 PM
Big MAC Cat or Tri? RHough Multihulls 5 04-22-2006 07:55 PM
Sea Pearl Tri 21 bfrowe Multihulls 6 01-18-2005 03:09 AM
