#31
It is aimed at those who want to go cruising in small multis, rather than the kind you'd want to live aboard. Jones' philosophy was that a small boat was quicker to build, required less time and money to maintain and fit out. None of his boats have standing headroom, for example. That isn't to say he didn't make notable voyages in his boats. He crossed the Atlantic more than once, and in his trimaran cruised the Atlantic circle. But he separated the functions of living and cruising-- much preferring his house for the former. Ray |
#32
| Thanks RayA. I have ordered the book, should be here in a few days,looking forward to learn some more. I have given the whole bi-rig thing a bit of thought, as to why the Radical Bay and maybe also other smaller bi-rigs might be underperforming. My theory is that if the relationship of the distance between the masts, and boom length/Sail Aspect Ratio are not good, then blanketing becomes more of an issue. i.e. a short wide sail compared to a tall thin sail. I also believe that by using good flat fully battened sails of AR>3 this problem can me minimised. It might still be a good idea to work a jib into the configuration if needed. This will give me 130 m2 of upwind sail area on a single rig, so performance should be OK. At the end of the day I stil think that SA/D still rules to a large extent, so having the power available is the best option. Regards Alan |
#33
| i like boats that are easy and low cost on building, big or small house has plenty more and other reasoning on a non racer boat with headroom and all comforts i belive living aboard is a good thing for boat and crew a while back i tried to read up on bi-planes a bit, learned a thing or two like the 6 or were it 7 way's the bi planes can be configured against each other like twist, stagger etc didn’t make that much difference long as keeping minimal a chord length in between the bi-plane could be attractive but had a hard time finding the nitty gritty on aerodynamics when using it as bi-sails not to many bi-plane confiurations windtunnel test to google while on a boat bi-rig pro's may still outweigh their cons |
#34
| Over on this other forum there is an interesting development discussion on a particular project: http://www.cruisersforum.com/forums/...ser-12688.html And here is another gentlemant that wants to experiment with a bi-rig, square rig variation: Square rig variation |
| Sail Loading on Rig, Rig Loading on Vessel | brian eiland | Sailboats | 93 | 02-23-2011 08:19 PM |
| New bi-rig performance cruiser | Nordic Cat | Multihulls | 21 | 02-12-2008 03:52 PM |
| X-rig / Millenium rig theory | wetass | Sailboats | 0 | 08-13-2007 09:38 AM |
| Multiplast does a Performance Cruiser? | Reality Fluno | Multihulls | 11 | 10-11-2006 09:49 AM |
| Performance Express Cruiser Molds - 45', 35' & 22' | whiticar40 | Boat Molds | 8 | 09-20-2006 06:03 PM |
