| Best software for designing Cats Hi, I was wondering what the best way to design a cat would be. As most software (Maxsurf, Fastship, the two I am familiar with) only design half a hull via nurbs surfaces. To get hydrostatics I know you can just tick a checkbox saying your design is a cat, but how accurate is this? what about the tunnel design (or whatever one uses to connect the hulls? what about complicated hull shapes such as wave piercing hulls? Can one design the hull in Rhino and import into Maxsurf to get hydrostatics? thanks
__________________ ~ www.davidmassey.weebly.com |
| The answer to all the above is yes. Maxsurf has a check box which is used to define if the surface is symetrical or not. I have also imported from rhino into maxsurf for the purposes of hydro/stability calcs without problems. Hydromax will show the immersed section data which will soon tell you if there is a problem. no idea of fastship though. |
| cabin/helm designing software | triumph34 | Software | 3 | 08-07-2009 08:42 AM |
| Best Software for Designing Multihulls? | CatBuilder | Software | 1 | 07-04-2009 01:05 PM |
| What software for designing a multihull | waynemarlow | Software | 5 | 09-29-2008 06:04 PM |
| Software functions for designing Cambered Stepped Hulls | flowtech | Software | 1 | 10-05-2007 05:52 AM |
| Software for designing a dugout canoe | BenJen | Software | 6 | 06-02-2004 02:47 AM |
