| Best propeller Does anybody have a book or an article to indicate me about choosing the best propeller to work with a motor in a specific hull? I mean that sometimes we use the charts thinking just in hydrodinamics, and frequently the motor cannot reach the maximum rpm. How can I solve for best performance of the hull/propeller and motor? Thank you. |
| Use this site to determine hull drag at your design speed and boat parameters: http://illustrations.marin.ntnu.no/h...ing/index.html Set the Options page on this site to water parameters, set the thinnest foil with the highest Re# in this calculator then set the thrust equal to the hull drag and it will provide a prop design based on your chosen parameters: http://colaco.freeshell.org/mhepperl.../jp_applet.htm The calculator works equally well for water or air props providing you set the Options for the medium. It is an analytical solution so does not rely on empirical data. If you have trouble working either calculator then post some more specific questions. Rick W. |
| "The Propeller Handbook" by Dave Gerr. They have it at Amazon.com. |
| Thanks for the answers Rick and Garydierking. I am trying to buy "The propeller handbook". I hear to say that it is a wonderfull book! |
| can anyone share the book "the propelleer handbook".. i am student.. i need it very much, try to help me if u have it smithjohn34@ymail.com thanks |
| Propeller design | skipper_rj | Props | 21 | 05-07-2008 09:07 AM |
| SP propeller | babakshabani | Surface Drives | 1 | 10-24-2007 06:56 AM |
| propeller | plattgatter | Marketplace | 0 | 06-13-2006 02:36 PM |
| Cruising propeller | Smarten | Props | 7 | 05-16-2005 07:19 AM |
| Propeller Efficiency | fredrosse | Boat Design | 3 | 03-16-2005 09:10 PM |
