Do you have some more photos? What materials did you use? I think you have a nice combination of lines between your hump in the outer hulls and the center pod. Nice looking design. |
| Spice It Up's design We finshed the boat in 2004, 9.5 months from renting the space in Loyang to her launch at Kepple Marina where the hulls, beams and Catbin (cabin) were assembled. She is mostly red meranti; BS1088 plywood, scarfed full length stringers over meranti web frames. More like airplane construction. There are 300 lbs of West System Epoxy, the hulls and foredeck are glassed. The main beams are 8" diameter, 0.35 inch wall 5086 H32 alloy rolled (bent) to a 37 foot radius and set in between mainstrength bulkheads in each hull. No flex, very strong! A simple boat designed to be built in minimum time with minimum material. |
| Not at all like a Wharram. ![]() |
| This forum never ceases to amaze me (in a good way). You ask the most obscure question and get a reply with all the details. Thank you Jeff for hosting what is a fantastic resource. |
| As a rule I do not follow forums of any kind. On Googling my name I found this forum because it was linked to my name so I had a look see. Of intrest to me 'cause Spice It Up has been put up for sale. My curiosity took me to the cruiserforum to have a look at the referenced thread. Amazing, loose answers to loose questions, can't see what help that is to anyone! I have an alergy to experts, especially those so ready to jump in with blabber about subjects they have very little real knowledge about. It missleads neophytes, confuses the critical issueas and does not serve any sound purpose. Reading and research are a much better and certainly safer way to garner useful information. Good bye and thanks. Last edited by Glenn Laurents : 07-19-2011 at 06:37 AM. Reason: Clean up mistakes and amplify |
| Who could have designed this yacht? | Leonardo | Motorsailers | 26 | 07-16-2011 08:47 PM |
| Self Designed Yacht | TheMoodyMonk | Boat Design | 42 | 08-20-2010 02:24 PM |
| Lighter than she was designed for. | BTScow | Boat Design | 3 | 09-20-2009 06:34 AM |
| So, I've designed a hull in.... | dkubiak | Software | 16 | 10-10-2004 05:06 PM |
| designed waterline? | huw | Boat Design | 3 | 06-05-2004 12:29 AM |
