| Any idea about New hull Shape Prismatic Coef ? Hi everybody, By new hull shape, I mean the new pierce-wave hull shape one can see on A-Cat for instance. Of course with one hull carrying the full load. In fact I would like to compare with more classic boats, in order to see if there is a trend. The only prismatic coef available for light Cat is the Tornado's I think ? It should be around 0.61 or 0.63. I need to check. Thanks in advance EK |
| can you explain a bit clearer what it is you are interested in, as your post title suggests a new hull shape, yet the body of the text suggests you're only after facts to establish a trend. care to elucidate? |
| Yes I would like to see if Prismatic has increased over the last 40 years: (New A-Cat shape vs Tornado shape). I guess it has, according to what I see. |
these numbers are based offsets from a laser scan of the hulls, one is Flyer, the other shall remain nameless, both are A-Class cats...hope this helps Flyer Length Units: m Origin Depth: 0.0000 Weight Units: kg Dimensions: L.O.A. 5.4864 L.W.L. 5.4755 Immersed Length 5.4864 Bmax. 0.3159 B.W.L. 0.3103 Immersed Volume 0.16 cu.m. FW Displacement 157.79 kg SW Displacement 161.74 kg Centroids: LCB 2.9270 (46.6 % aft) LCF 2.9917 (45.5 % aft) TCB 0.0000 VCB -0.0686 Coefficients: Block (Cb) 0.513 Prismatic (Cp) 0.633 Midships (Cm) 0.810 Waterplane (Cwp) 0.754 Volume (Cv) 0.961 Areas: Water Plane 1.281 sq.m Wetted Surface 2.294 sq.m Ratios: L/B Ratio 17.644 D/L Ratio 26.73 Immersion: Load Increment / Draft Increment 1281.15 kg/m Metacentre: Transverse Radius (BMt) 0.0458 m Nameless Length Units: m Origin Depth: 0.0000 Weight Units: kg Dimensions: L.O.A. 5.4864 L.W.L. 5.4196 Immersed Length 5.4864 Bmax. 0.3000 B.W.L. 0.3000 Immersed Volume 0.16 cu.m. FW Displacement 158.08 kg SW Displacement 162.03 kg Centroids: LCB 2.9606 (46.0 % aft) LCF 3.0550 (44.3 % aft) TCB 0.0000 VCB -0.0687 Coefficients: Block (Cb) 0.535 Prismatic (Cp) 0.696 Midships (Cm) 0.770 Waterplane (Cwp) 0.755 Volume (Cv) 0.993 Areas: Water Plane 1.228 sq.m Wetted Surface 2.291 sq.m Ratios: L/B Ratio 18.066 D/L Ratio 27.62 Immersion: Load Increment / Draft Increment 1227.69 kg/m Metacentre: Transverse Radius (BMt) 0.0431 m |
all these are at full load, the one posted here (new Geltek Flyer that Ashby sailed in the Aussie Nats) is an extrapolation from the original Flyer based on the description of the changes posted on catsailor...not sure how accurate it is, but if all the changes where described accurately, it will probably be close New Geltek Flyer Length Units: m Origin Depth: 0.0000 Weight Units: kg Dimensions: L.O.A. 5.4864 L.W.L. 5.4769 Immersed Length 5.4864 Bmax. 0.3159 B.W.L. 0.3090 Immersed Volume 0.15 cu.m. FW Displacement 152.95 kg SW Displacement 156.78 kg Centroids: LCB 2.9470 (46.3 % aft) LCF 3.0275 (44.8 % aft) TCB 0.0000 VCB -0.0661 Coefficients: Block (Cb) 0.514 Prismatic (Cp) 0.636 Midships (Cm) 0.808 Waterplane (Cwp) 0.766 Volume (Cv) 0.931 Areas: Water Plane 1.297 sq.m Wetted Surface 2.254 sq.m Ratios: L/B Ratio 17.724 D/L Ratio 25.89 Immersion: Load Increment / Draft Increment 1296.66 kg/m Metacentre: Transverse Radius (BMt) 0.0485 m |
| Thank You So Much Questioner Hi Questioner, Thank you very much for all these datas and for taking time to answer. I am very curious about the software you use to get all these figures. Also, I am happy to notice that you are interested in A-Cat hull design, as I am. I was expecting higher figure for the Flyer You mentionned your data acquisition system with laser. On my side I have a few datas on the Flyer I, and according to these measures, the max beam seems to be around 290 mm, may be 296 mm but no more. May be it can help to adjust your modelization. I guess that new LR3 shape with very narrow hull will achieve a very hight prismatic. Do you have any design project on the back-burner? Thank you again Best regards EK |
| Hull shape help please | Fanie | Multihulls | 16 | 01-09-2009 02:10 AM |
| Prismatic coefficient for deep vee planing hull | Mamaboo | Boat Design | 4 | 08-08-2008 07:35 PM |
| Can You Help Me With The Shape Of My Hull | rich99uk | Powerboats | 10 | 08-16-2007 05:10 AM |
| Which Hull Shape? | monrosm@shrewsb | Boat Design | 8 | 08-10-2006 11:54 AM |
| Hull Shape | mrbrown | Boat Design | 1 | 08-09-2004 12:24 PM |
