Old 10-26-2011, 04:17 PM
oldsailor7 oldsailor7 is offline
Rep: 269 Posts: 1,118
Doug Lord said--- "a planing ama may work on small high speed trimarans"
A case in point was the Piver Frolic. It was very fast.
The floats were of box section and if you took away the sides and deck you were left with a pair of water skis.
Since the floats were lightly loaded it worked very well at that size.
Old 10-31-2011, 09:53 PM
upchurchmr upchurchmr is offline
Rep: 224 Posts: 528
There were some AYRS guys who put retractable foils on a day sailing catamaran, a long time ago. The inverted T foils were not particularly large, so only worked at a high speed, which was fine with them since they felt no foil was more "efficient" at lower speed. These were not submerged very deeply and it was noted that they ventilated at a certain speed. There was some wishfull thinking that they could increase the size a little, and when they ventilated they could be given more of an angle of attack and act as a ski or planing surface. No report that I saw ever said this was proven to work.
Marc
Old 10-31-2011, 11:22 PM
Yes there was a guy who took a 30 ft Piver Nimble and fitted hinged retracting ladder foils to either side and at the stern. He sailed it across an ocean (I think the Atlantic). He found that the conditions had to be just right for the foils to be effective, and its crossing time was nothing special as a result. It was all written up in an issue of the AYRS.
Old 11-01-2011, 12:42 AM
Rep: 457 Posts: 1,404
That was David Keiper in Willwaw but although it looked Piver-like, was his own design with smaller floats; here is Williwaw (left photograph) when he crossed the Pacific to Auckland. I went aboard and had a very interesting talk to him.
Another Question About Tri Hulls-williwawcopy.jpg  Another Question About Tri Hulls-williwaw1.jpg
Stabilized Monohull (tri hulls) Powerboat for Cruising brian eiland Boat Design 5 08-12-2011 03:25 PM
need help for quick & dirty tri: which design for P19 rig/hulls? Fritze Multihulls 7 04-14-2011 09:13 AM
Kraken 25 trimaran rebuild and question re: boarding step for off the beach tri Corley Multihulls 11 07-19-2010 08:14 PM
yet another mono/tri question HeavenBound Multihulls 28 08-05-2009 05:26 AM
Raw intakes, exhaust and other thru hulls on Fiberglass Hulls ChrisN67 Boat Design 7 12-27-2008 12:40 PM
