Old 07-16-2008, 09:24 AM
luftspringaren luftspringaren is offline
Rep: 10 Posts: 3
amateur wingmast
I am thinking about building a carbon rotating wingmast, does anyone have any hints on simple amateur DIY methods to use?
Do I really have to build a female mold or are there other ways?
I will have to get an expert to calculate the structures of course.
Luftis
Old 07-16-2008, 06:16 PM
Petros Petros is offline
Rep: 717 Posts: 764
There are a couple of ways to do this without a mold: one is to build it like you would a strip hull construction, with little cedar strips, in two halfs and glue together. Another is to use a hot wire cut foam core. You can even solvent-melt the foam out of the mast shell when done. If you seach the archives there are links site with pictures of these methods.
Old 07-16-2008, 09:53 PM
rob denney rob denney is offline
Rep: 318 Posts: 332
Luftis
G'day,
I sell plans and materials for building a carbon/foam wing mast (stayed or unstayed) with integral sail track and all required fittings that does not require a mould.
Depending on the detail required, our engineer will calculate the scantlings for about $800.
regards,
Rob
www.harryproa.com
Old 07-17-2008, 12:14 AM
Rep: 527 Posts: 792
These guys have the coolest materials for making masts; braided and unidirectional carbon sleeve.
http://www.braider.com/index_lo.html
If your mast is on the long (tall?) side, you'll need to carefully select the resin system and curing schedule to avoid problems.
Jimbo
Old 07-18-2008, 09:32 AM
Doug Halsey Doug Halsey is offline
Rep: 65 Posts: 45
Gary Baigent briefly discusses how be built a wingmast in the following thread: Boat Design Forums > Design > Multihulls
Hydrofoil Trimarans in New Zealand : Attn Gary Baigent
(See the last post, to date)
Old 07-21-2008, 06:15 PM
waltm waltm is offline
Rep: 15 Posts: 13
There was a post on catsailor about building strip plank / carbon masts a while ago and a build log. Might be worth a look.
Building a mast
wingmast/shroud interaction- hardware Paul Scott Multihulls 11 07-29-2008 02:12 AM
TAll wingmast catamaran rig on a skiff? wind_apparent Multihulls 19 04-29-2008 09:25 PM
A design from a amateur Peter H Boat Design 8 05-29-2005 09:58 AM
How to build a wingmast?? StriderTurbo Boat Design 15 02-06-2005 04:32 PM
rotating aluminum wingmast Doug Carlson Sailboats 14 09-28-2003 01:52 PM
