brian eiland
Summary thus far, & New Stock Design
Hello Kimosadler,
I believe you have received some interesting advice on this subject tread you started, and hopefully more will be forthcoming. I am not an alum expert at all, so I will make only a few observations about it as a building material for a catamaran..
In order to end up with the most rigid vessel in aluminum, I think Simon expressed it well:
____________________________________________________________________________________
Most quality aluminum boats I’ve seen utilize an insulation material that is cut into sections to fit between the ribs and stringers and adhesively bonded to the inner hull alum sheet. This allows for different qualities of insulation materials, spot repairs, and far less mess. Any welding heat around polyurethane residues could create poisonous gases.
I might add there was another 59 foot alum cat I inspected in Fl that had really done things proper with respect to the proper adhesion of the insulation material. We all know of the difficulties of keeping paint adhered to alum….requires a proper etching job. This boat’s inner alum structure had been painted with an etching primer prior to adhesion of the insulation material. I think I still have some photos of that vessel…very nice home fit-out.
At some point in your life I will place a bet that you will want to try and salvage some of your investment out of this vessel….either to get out of boating and on to something else, or to build another dream vessel, It’s not really that much more difficult to build a nice looking design than a poor looking one. And that nice looking vessel will be much more marketable than a clunky one,….even if its just the overall structure’s looks verses the quality of fit-out. On the other hand you may have invested a considerable amount in quality gear and fit-out of engines, electronics, sailing rig, etc, etc, and hope to recover some of these monies. If these quality items are on a clunky vessel it might prove to be much more difficult to recover your investments. Remember the cost of the hull and deck structure of a vessel is probably only 20-25% of the total cost of building a vessel.
And finally, remember the cost of the architect is WELL WORTH the fee he charges in the theme of things. That advanced planning and guidance could well save you more than his fee of 10-12%.(sometimes much less with ‘stock plans’)
Simon, it’s interesting that you brought up the design site of David deVilliers I consider that 62’ ketch rigged alum cat of his to be a really excellent design. In fact I have been in some talks with him about representing that particular design for, and with him. Here is a portion of that proposal:
So now I come back to the idea of developing primarily ‘two stock designs’ that could satisfy the great majority of my inquiries. I’m defining these two as a 65-ish & a 50/55-ish. I believe these two sizes can fulfill the desires of many clients who might consider a ‘good size private vessel’. If they want something smaller, send them to the production vessels…for something larger, it will involve a custom design.
I really like your 62’ ketch design…so much so that I would be interested in channeling my inquiries for this size vessel to your design. It would become the larger of the two ‘stock designs’ that I’m seeking to establish…the 65-ish one. I presently have two fellows looking at 55 and 56 respectively; that I believe could be talked up to the 62’ (and leave the extra ends of the vessel empty, or lightly loaded). I also have quite a mailing list I would like to go back thru and present this alternative.
I found it interesting that you were also working on a 50 plan. A 50-footer & a 62-footer could well fit into my ‘two stock design concept’. I’m assuming you might make this 50 footer a stock plan as well??
David has considerable experience with aluminum boat design. In fact he was brought in to help with Steve Dashews challenging development of his FPB vessels. He also has computer cut-files for this 62 vessel, and could have them for the 50 footer. These files can save considerable time in construction as well as avoid costly mistakes in cutting all the alum pieces.
What’s not to like about this??
So do you think you two fellows could agree on a 'stock design' that would have appeal to the market as a whole? Or would you both go separate ways and have a custom design done?? That 62' design is MOST appealing in its class.
Some photos of that 59 footer with superb building details
Hello Kimosadler,
Global stresses in a multihull are important both in being able to maintain a rigid base for the rig, and a rigid structure athwartships. And this is an important factor for longevity, as the vessels flexes over its lifetime. The homogeneous sheet aluminum material lacks the rigidity of the steel and sandwich composite. I believe web- reinforced alum sheet is considerable better in this respect. I might also question the true puncture resistance of the 12mm plate over the 10mm plate. Is it really that much superior that its worth building in the heavier material?I think the advantage of strongall is that you have hull-skin that is very resistant to localized impacts. I am not sure about more global stresses, as the properly designed thin plate construction with stringers and frames may be overall stronger.
You appear to have the expertise to construct a nice aluminum vessel, so I might think you would spend the little extra time required to build the slightly more sophisticated version of the alum vessel. Particularly since light-weight is an important factor in the performance and weight carrying capabilities of multihulls. Besides the lighter weight vessel just might make her less susceptible to impact damage by virtue of carrying less momentum into the impact incident.I have my shop built, have 25 years of welding/fitting experience and am ready to make it happen. Of course I will need all the help and advice that I can get, and would appreciate conferring with other builders.
I have a 65 ft strongall-type monohull under construction. It is fast to build & ice-ready.....and....30-40% lighter than a steel hull.
You are most probably familiar w/pros & cons of cats. One of the biggest problems is weight. Not a sure a strongall cat would make a seaworthy & good performing vessel. As my last project, we built a 53 ft AL cat. The sister ship made it across the Great Barrier Reef---literally---ran aground, no hole. We sailed ours around the world & had several instances where a foam sandwich cat would have gone down. The cat was built on bulkheads with T-bar stringers. Underwater she was built in the lobster tail system & had double floors for safety. This boat was also fast built.
What can I say, I am an AL convert after years of professionally building steel vessels! For cats, I would strongly consider the weight of the strongall system. For a 40fter would not go strongall.
I took my thin plated aluminum monohull to Antartica and thought that it withstood quite well the ice.
I would give serious considerations to investigating this idea further. I once saw a beautiful newly constructed 53 foot French cat down in Lauderdale that had had foam sprayed the inner surfaces of her alum hull. There was some sort of defect in the welding job that was going to have to be corrected, and the huge job of getting all that foam and its residue unstuck and washed, and etched from that alum structure was going to be so costly and intrusive to the cosmetic interior installed already, that the boat was declared a total lost and sold for salvage value.Insulation will be 'blown-in' polyurethane foam 20 to 60 mm finished with easy to clean vinyl like Manta Cats have.
MARKETABILITY. I just don’t think enough emphasis is put on this appearance aspect sometimes. For instance, have a look at the photos I found of that alum cat I spoke of as being put together marvelously with lots of attention to detail. I would not refer to this vessel as pretty…its clunky looking!! I believe I have detected that you (kimosalder) are not concerned with the looks that much…just a good tough vessel??...my advice, choose a pretty yacht.... she will be worth much more
I've been searching for plans for a strongall process aluminum sailing catamaran in the 40' to 50' range.
STOCK PLANS..please keep me updated on your progress. I am planning to build a aluminum catamaran soon. Simon
