| Aluminium Wing Mast Do you know anyone who could use this? Super deal for the right builder. Contact me off-Forum for details. 6" X 15" X 66'-1" Francespar aluminum wing. Complete with single spreaders, double rod diamonds, all shrouds, turnbuckles, pins, masthead crane, 2 5/16" aluminum rotating mast step cup with delrin insert, 22mm aluminum female "T" main sail track with sail slides. (No winches or stoppers.) Complete Harken MK II headstay furling system including top swivel, single line furling drum and extrusions. Working length is 56'-9". This system is recent and in excellent condition, may be available separately. In Newport, RI |
| Perhaps you contact Phil Stegall who is building a 42' Trimaran in Jamestown, RI. Even if he prefers a carbon mast ... perhaps he is connected to the Multi sailors and can make you a good contact.http://www.buildatrimaran.com Greetings from the North Sea Coast, Michel |
| I know him well, cool project. He is committed to carbon but thanks for the thought. |
| any further details on this any idea of weight per metre? Slightly shorter than the mast I need but I'm interested. |
| maybe a few photos of step, head etc. to show condition. tks. |
| Wing Mast Details ROTATING WING MAST 6" X 15" X 66'-1" Francespar aluminum wing. Complete with single spreaders, double rod diamonds, all shrouds, turnbuckles, pins, masthead crane, 2 5/16" aluminum rotating mast step cup with delrin insert, 22mm aluminum female "T" main sail track with sail slides. (No winches or stoppers.) Complete Harken MK II headstay furling system including top swivel, single line furling drum and extrusions. Working length is 56'-9". This system is recent and in excellent condition, may be available separately. Better pictures to follow these should help a bit. |
| Corley, Weight is in the 7-800 lb range for tube and furler. Consider a Le Rouge style mast stepped on a post if you need extra length. Ted |
| Better Pictures The splice would be tough to remove and re-do. We have a gantry here and could load on a boat hauler's truck. Probably easy to get it to FL area for installation. Move quickly as we are going to do whatever soon. |
| thanks for the info but not suitable for my application as the section is too heavy I'm looking for something about 6 lb a foot and I would have needed the mast unspliced for container transport. |
| Yes, I'm interested. Please send an e-mail to my username @gmail.com. Thanks. Paul. |
| rotating freestanding wing mast section and mast bend | Timothy | Sailboats | 6 | 06-25-2010 11:53 AM |
| Wing Mast Battens | earthsail | Multihulls | 1 | 10-07-2008 10:09 AM |
| Rotating wing mast | john olsson | Multihulls | 4 | 06-11-2007 07:06 AM |
| aluminium wing mast extrusion | joshy7 | Materials | 0 | 02-01-2007 05:27 AM |
| Wing Mast Construction | Phill Wise | Sailboats | 4 | 09-19-2004 08:29 AM |
