  #256
Old 10-30-2011, 02:00 AM
Rep: 451 Posts: 1,842
Here is a wing frame, full size; 1.5 metre chord plus there will be a trailing edge flap and also a leading slat so the platform will total around 2 metres chord - and all three elements will be able to rotate. The idea will be similar to the French C Class OTIP ... but their big problem was that the main element was fixed fore and aft, (it could pivot from hull to hull of course) only the flaps/slats (there were two neat trailing edge flaps) could be moved ... so they couldn't bear away in string gusts, even though the rudders were very large, result, capsize. Well, that is my interpretation. But I like their narrow rig platform and the boat was apparently extremely fast in light airs. So that's what Sid is going to have: 11 metres tall, with a 5 metre central mast, the hard wing pivoting in the central area to tack and gybe ... but able, through the double bearing design, to be rotated like a conventional wing mast. To cure my problems of mooring the boat, the wing will be set horizontal, like an aircraft, but with negative angle of attack.
The big gains are the asymmetrical foil wing shape, very high lift and less drag than a symmetric wing or soft sail combination.
I actually built a wing like this a couple of decades ago for Misguided Angel but it ended up being too large and way too heavy … so I scrapped it and went more conventional with wing mast/soft sail. Sid's rig HAS to be light. Give me a month to complete it, Doug.
Alternative to marvelous Buccaneer 24-69fu5595.jpg  Alternative to marvelous Buccaneer 24-otip-copy.jpg  Alternative to marvelous Buccaneer 24-sidfrontview.jpg
  #257
Old 10-30-2011, 02:14 PM
jamez jamez is offline
Rep: 208 Posts: 331
Originally Posted by Gary Baigent View Post
Sid with small cabin, extended stern, carbon reinforcing beam/float attachments.
hey Gary, I went down and checked Sid out on Friday last. Looking really good. can't wait to see her sailing...
  #258
Old 10-30-2011, 06:59 PM
DennisRB's Avatar
DennisRB DennisRB is offline
Rep: 103 Posts: 576
Cant wait to see the wingsail done. I really like the idea of a flip tacker style wing. I have never seen this idea applied where only the sail flip tacks rather than the whole craft. Once it is complete will it hang off a mooring that does not dry out? The foils look quite fragile to be drying out like in the pics. I have a heap of old RC glider wings I am tempted to make a RC flip tacker our of now.
Gary, if I end up cruising to NZ next year on my sail back from California to Brisbane can I come check this beast out?
  #259
Old 10-30-2011, 07:15 PM
You don't have to ask permission to look at Sid, Dennis; it's moored at the mouth of Motions Creek, to the east of Meola Reef in the Waitemata above the bridge. If you check Google or Flash Earth, you'll see the boats moored there. Cheers.
  #260
Old 10-30-2011, 07:24 PM
Oh, sorry, the foils are retracted - and they're mostly carbon, and they stay clear of the waterline (or just on it) when lifted. But with an inclining wing, unlike a vertical, convention wing rig, there are not the heavy side loadings on the platform if the wind oscillates and comes on the beam, therefore no pressure on the foils. But a horizontally moored rig is going to produce minimal to no side loads on the platform. The foam/glass pads temporarily tied to the curved area of the foils, will be redone and improved later; at the moment the temporary ones do the job fine.
  #261
Old 10-31-2011, 04:38 AM
Samnz Samnz is offline
Rep: 47 Posts: 232
What would be the limiting factor in terms of the top speed in your opinion Gary?
Could it hit 30 knots in ideal conditions?
  #262
Old 10-31-2011, 12:49 PM
Rep: 148 Posts: 1,298
I like the rig idea Gary. In a way Sid still scissors
  #263
Old 10-31-2011, 06:31 PM
Ah, I don't know, Sam; it will be quick is about all I can say. I think the J lower section of the foils will not ventilate like angled straights because the lifting sections are more deeply immersed. But time will reveal whether this is true.
Right, Cav.
  #264
Old 11-09-2011, 10:54 PM
Sid's skeletal wing, 11.5 x 1.5 metres.
  #265
Old 11-10-2011, 07:41 AM
Doug Lord's Avatar
Flight Ready
Rep: 1101 Posts: 7,435
Gary, whats your reasoning on symetrical vs asymetrical section? With the tilting rig I think you're going to have asymetrical would have been possible, right? Congrads on the progress-good luck!
yes, it is a Revolution
  #266
Old 11-10-2011, 03:56 PM
Doug, if I'm reading you correctly, you think this rig is symmetrical, no, no, it's asymmetric - maybe the 28mm lens makes it look equal sided. Here's a shot taken this morning, before I rip down some more stringers and diagonal supports.
  #267
Old 11-10-2011, 05:29 PM
Doug Lord's Avatar
Flight Ready
What a difference-I can tell now.
  #268
Old 11-10-2011, 11:38 PM
farjoe farjoe is offline
Rep: 26 Posts: 122
Gary,
It looks like you have gone for a plywood structure for your wing instead of carbon.
Would you care to comment on any weight penalty expected and if you think it will significantly affect the final results?
Plywood sure is more easily available to most of us.
  #269
Old 11-11-2011, 12:24 AM
Farjoe, yes, ply is affordable; you can see I've cut holes to get minimum weight from a low tech material but there will be some uni-directional carbon going onto the thin ply outer skin especially surrounding the pivot box bearing area (plus the bearing which will be solid carbon) and the I beam; carbon would be just wasted on the frames, just imo. The stringers and diagonals are in white cedar. The thing with a wide and quite deep wing is that the shape itself is a good one and can be built light and stiff in not expensive materials. I'll weigh the wing when complete; it will be light, not just light, light.
  #270
Old 11-11-2011, 01:01 AM
Corley's Avatar
Corley Corley is online now
epoxy coated
Rep: 619 Posts: 1,596
The Americans challenged for the little america's cup with a C class running a similar rig (wingmill? I think it was called) it seemed fast but the wing section self destructed during the racing so its hard to get a measure on how fast it was relative to the more conventional wing on the Linday Cunningham designed Australian C class. Looking forward to seeing how it all goes.
Buccaneer 28 Trimaran plans. oldsailor7 Multihulls 284 05-14-2013 01:00 AM
Buccaneer 24 Trimaran Samnz Multihulls 489 05-04-2013 07:07 AM
Buccaneer 24 Builders Forum oldsailor7 Multihulls 1420 05-01-2013 06:36 PM
Bayliner Buccaneer 295.. Oh and hello! jboswell Sailboats 24 01-25-2011 01:22 AM
K24T versus Buccaneer 24 gpb Multihulls 70 07-28-2010 06:36 AM
