| 70+ long ally or steel cat The actual build time is about 5 years away. In the meanwhile the idea is to use metal from shipping containers to make the hulls might have to try and rivet hulls together to make it thick enough steel shipping containers http://www.containersnow.com/contain...sonville/4.htm Aluminum shipping containers http://www.containersnow.com/contain...sonville/5.htm problems i can see quite clearly are the shipping container skins are to thin. 1/16 an inch thick for ally 14 gauge on the steel I plan on propulsion using 2 400-500 hp marinized tractor trailer engines take up the criticism on marinizing engines ect on the link here Rebuilding and marinizing tractor trailer link to marinizing the engines are here Well all the best rip my idea a new one so that i can know what i need to do and what i need to learn. |
| I am not sure what answer you are looking for here But there is no way of saying politely that your idea is ,quite plainly riduculous i want to tell you now, there are many (right) ways to build a boat, but there are no short cuts |
| say what dude that is what my children say when i make grunting sounds ![]() |
| Why Not doubting the wisdom of those more experienced then me (currently 97% of members) but its know help to tell me its ridiculous unless you tell me why |
| I think what my fellow members are trying to convey to you is: It is great to see that you are thinking of alternative, recyclable, materials to build a vessel from. Environmental Greenies from around the world would applaud your concept of recycling scrap containers into a 70' Gin Place. However, when building a boat you must always consider the safety of others first. If you have a family and friends, and plan to use this vessel with them on board then you should construct this boat to the highest possible standard and care. This process should start with a good design and followed through with correctly specified building materials suitable for marine applications. There are a number of economical construction methods available for "Do It Yourself" builders, but the ones you have mentioned do not fall into that category. Always remember: If you start your boating life with a substandard boat made with substandard materials, it will be a very short boating life. I wish you all the best in finding a safe and suitable solution to your future boating project. ![]() |
| Thank you Thanks for the post so i will drop the pursuit of shipping containers as a hull. Maybe move on to seeing if i can melt down aluminum beer kegs into sheet. It would take about 550 kegs to make 8 tons and if this shall be the case i dutifully swear to attend enough keggers to reach my goal ![]() |
| Switching plans The container idea is off/ scratched out even though i think i may have had something with recycling keg cans. I think that even if i did manage to recycle melt down process and alloy then press it into sheet I wouldnt trust myself to weld it so i figured I'd go to a more easily workable material thanks for all those people who took the time to reply or view this post My latest post is here http://www.boatdesign.net/forums/sho...114#post199114 and just so its known if one of my first idea's ever dead pan out I'd mostly like go into shock.
__________________ A bloody foolish amateur but at least I admit it. High Priest of the first church of David J Gingery http://www.lindsaybks.com/dgjp/index.html Chancellor for the cult of backyard foundrist's http://www.backyardmetalcasting.com/ |
| mad dogs and englishmen/yadda |
| Rats! You bailed out before I could finish the math! There is about $1145 worth of scrap aluminum in a container. You could burn out the wooden parts and shred the remainder to magnetically extract the ferrous materials (Hinges, lock mechanisms, nails, etc.) for less than 1200 dollars, buy the boat in the right state, declare it your residence then declare bankruptcy and voila! You have a boat. And you have become a name to be reckoned with at several government agencies! |
| Oh really I may have to go further into this plan with you. I am a dual citizen after all i can lay low in other countries for awhile if it means lifetime freedom
| http://www.flickr.com/photos/25569561@N08/ Check out the Malt's Mermaid catamaran built out of aluminum beer kegs. It crossed the Pacific! |
| Free of charge, Steel - polyurethane foam -Steel insulation sheets | rossgiles | Fiberglass and Composite Boat Building | 0 | 03-18-2008 07:43 AM |
| How long will interior paint on steel last? | hiracer | Metal Boat Building | 21 | 07-12-2006 01:51 PM |
| Rig handling: Cat Ketch, Cat Schooner, Sloop, Cutter | Seafarer24 | Sailboats | 8 | 05-30-2006 11:06 AM |
| Steel Cat | Bali Dream | Metal Boat Building | 2 | 02-03-2005 11:26 PM |
| Steel Cat | Fitcher | Metal Boat Building | 2 | 10-06-2004 01:36 PM |
