| 5m sport multihull new design Hi All, This is my first message here but I have been happy to read you for some time now. Here is my project: a 5m trimaran. It would be a sail boat for daily raid. Friends, family and good fun and speed. Here are the main fixture of the design I have in mind : 5m long for the main hull, 4m for the floaters, 4m wide weight? 100/120kg Sail area : main :14m2 gib: 4m2 spinnaker :20m2 Floaters about 300% of the displacement One rudder and one derive sabre on main hull Construction : I need to be able to build it myself in a reasonable period of time. For the 3 hulls, I would like to use the technique of thin plywood +carbon epoxy reinforcement such as used here : http://www.moth.it/MarcosCorner.htm the “roof” would be used only for the main hull to help supporting the mast, the bow could be inverted to be a bit wave piercing, just for fun. 2 arms in straight carbon tube through the main hull bolded in the hulls. Carbon mast unstayed such as http://www.juanyachtdesign.com/projects-krazykyote.html for such a small boat you just need to oversize a little bit the mast section. I would like this boat to be light but strong, the ply wood would helpfor the shape and resistance, the carbon too. I have no really budget for this construction that is why now I say carbon but it could be reinforcement in fibreglass, arm tubes and mast in aluminium too… Any ideas welcome, comments too josselin |
| Would you be wanting to fold the amas for trailering? If so, that mechanism will be very important for your design. |
| You probably already saw this: http://homepages.paradise.net.nz/garyd/Trimaran.pdf http://www.lunadadesign.com/ |
| thanks for the links, it can help and gives ideas. yes it could be folded or i would say dismanteled : the arms bolded on the floaters and central hull could be removed to allow transportation. i should scan some of my designs for you to have a better idea |
| alloy sport fisher cat 8-9m design | karuhi | Multihulls | 2 | 05-15-2008 04:58 AM |
| multihull design texts? | samh | Boat Design | 4 | 01-18-2005 02:59 PM |
| 48+ Sport Fisherman Design | Bordersles | Boat Design | 0 | 06-10-2004 07:05 PM |
| folding multihull hull design | grob | Multihulls | 19 | 07-01-2003 10:32 AM |
| multihull design | Boat Design | 12 | 01-24-2002 11:09 AM | |
