  #61
Old 11-28-2016, 06:58 AM
UpOnStands UpOnStands is offline
Rep: 16 Posts: 290
lightweight
lightweight but practical furniture - sounds like just what a lot of builders need.
expensive? strictly one-off?
  #62
Old 11-28-2016, 07:48 AM
bscatam bscatam is offline
Rep: 16 Posts: 65
Not so expensive. According to my calculations 1 sq.m. will be around 1 -1,1 kg for 18 mm thick panel. But I am in Europe.
  #63
Old 11-28-2016, 01:38 PM
Rep: 790 Posts: 1,142
Gday Bscatam
I have used a product called Featherlight in some of my boatbuilding (along with Duflex) These are cored panels from ATL. The Featherlight is somewhat like what you have but with a glass laminate instead of the timber your panels have.
Featherlight is nice stuff, stiff and strong enough for most interior uses but it is a real time black hole when dealing with its edges. I have to rout or dig out the core to a depth of about 10mm and then cove in a nice rounded edge of epoxy bullnose fillet. I can't ever get it done in one go. If I make the epoxy thick enough for a one time pass then I get little voids in the mix. A fair bit of sanding and filling is involved. In the end I am happy with the result but there is a lot of effort required.
If you can get a really strong and watertight edging that would be great BUT I would urge caution and the making of lots of small test pieces. I would not like to have the Featherlight have any exposed edges inside a boat - it could turn to mush with long term exposure.
I would also urge caution about using the Lagoon style interior fitout for a light cat. In the small amount of time I have spent on condo cats - a Lipari - I was surprised to see that the furniture is not integral to the hull structure. Of course the hull laminate is beefed up accordingly but I couldn't get my head around the fact that the cupboards were not used as part of the hull stiffening. If you put your keys on top of the cupboard they could fall down between the cupboard and the hull. It seems a waste of all that amazing stiffness but it probably saves hundreds of ours of fitout.
I can get the idea that you could CNC the furniture in a day but I would think it would take a few weeks/months to install. Coves, even where the interior panels meet, are a bugger.
cheers
Phil
  #64
Old 11-28-2016, 03:22 PM
groper groper is offline
Rep: 693 Posts: 2,149
Well assuming you use okume or similar density timber for the plywood, I have 1.68kg per sqm just in the wood. Add the glue and the veneers and the honeycomb on top of that, I'd say your about double your calculations...
  #65
Old 11-28-2016, 08:38 PM
DennisRB's Avatar
DennisRB DennisRB is offline
Rep: 228 Posts: 1,232
How about XPS as a core? At least is waterproof...
  #66
Old 12-01-2016, 04:22 AM
Gus7119 Gus7119 is offline
Rep: 18 Posts: 110
Love it. Its come a long way from the humble beginnings. You'll always have diffrences in peoples likes and dislikes az long as it make you happy, I myself like it. Can see a lagoon influence slightly. But they sell alot of boats ao must do somethings right.
As for the raked windows I did a while ago see a wid tunnel video at a boat shead with raked and verticle but the difference from memory was not worth discussing. The diffrence came when they lowered the coach house and made some alterations to the hull shape. But your never gonna get rid of it and unless its a race boat or speed is the goal as long as it comfortable and gives you satisfaction you should be proud as it will by the looks be a lovely boat.
The only question I have is the coach house roof. As gropper mentioned earlier a flat to to stiffen can be difficult, add a little curve and its much easier. Would love to know your solution for this, is it maybe a central post or materials?
Regardless just a fantastic effort. Now for the painful bit. The Dam build. Hope your able to get it done quickly unlike the many who start and 10 years latter have a blank empty hull sitting in a paddock roting.
Best of luck.
  #67
Old 12-02-2016, 03:39 AM
Rep: 16 Posts: 65
Thanks Gus. Coach ruff actualy has a slight curve it is not flat.
40 ft cruising cat design. First steps.-cab3.jpg  40 ft cruising cat design. First steps.-cab1.jpg
  #68
Old 12-02-2016, 03:43 AM
Rep: 16 Posts: 65
Yes. It's possible. But not shure about thin ply. You need special glue. Chek with SIP pannels for prefabricated houses which type they use.
  #69
Old 12-02-2016, 03:47 AM
Rep: 16 Posts: 65
Fast cat.
Just playing around fast cat. 45 ft profile.
  #70
Old 12-02-2016, 06:14 AM
DennisRB's Avatar
I think even with a slight angle, like in your second post, the aesthetics will be much improved with no real downside. You had it right the first time. At the bare minimum you will get less comments about it being a lagoon.
Nice fast cat. Can you shave much more freeboard from the hulls and still have head room? Rudders look small. Edit, I just zoomed and saw the head room measurements, not really. As for this roofline, I think a higher profile at the front would have no real downside on performance but a lot of benefits inside A shallow rake does look fast though.
  #71
Old 12-02-2016, 11:16 AM
Rep: 16 Posts: 65
Fast cat.
And some fast sections to fast cat
profile
40 ft cruising cat design. First steps.-fc4.jpg  40 ft cruising cat design. First steps.-prof.jpg
  #72
Old 12-02-2016, 09:43 PM
waikikin's Avatar
waikikin waikikin is offline
Rep: 871 Posts: 2,195
Those more vertical sides probably put a hand rail in easy reach. One of the styling things I've seen on the sloped cabins is louvres that act as steps, pretty sure Leopard has them on the front, only remember seeing them on the side on a Hitch 40 a lot of years ago, maybe you could have steps up the sides with glazing to the risor section... might be the next big thing in cabin styling
Jeff.
  #73
Old 12-03-2016, 07:43 AM
Rep: 16 Posts: 65
Testing lines. This is a huge advantage of 3D CAD software. You can virtually correct all mistakes in lines and surfaces.
  #74
Old 12-04-2016, 10:39 AM
Rep: 16 Posts: 65
Fast cat. Not racked windows
Playing with lines. Racked
  #75
Old 12-05-2016, 12:14 AM
waikikin's Avatar
Are the missing topsides a developed surface for sheet materials... Starting to look "Spirited".
Jeff.
Crowther design 226A (42 foot cruising cat) DennisRB Multihulls 14 04-03-2017
02:51 AM
Help with design first steps? voodoo92 Boat Design 12 05-27-2014
02:21 AM
22m cruising cat design concept Becaris Multihulls 114 09-07-2009
09:34 AM
What are the steps to getting a patent on a design? AlaskaFisherman Boat Design 13 07-23-2005
05:02 PM
Summary of Power & Propeller Design Steps JohnHeart Boat Design 8 07-08-2003
04:01 PM
Powered by: vBulletin Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
Web Site Design and Content Copyright ©1999 - 2017 Boat Design Net
