| 39' Wavepiercer Flint Design Trimaran Here is an interesting Trimaran that I found on yachtworld. Does anyone know who Flint is or know more of the story behind the design? The sales info just comments that he passed away before being able to finish production. ![]() This design looks like an interesting compromise between a regular trimaran and a monohull. The amas are small and fairly close together so that the beam is not so great. Presumably you could get this boat in a normal 40' berth. Also interesting is that they claim that with a gas engine this boat could do 20 Knots. The gas engine has been replaced with electric and it only does 5 Knots now. Any advice for a potential buyer? If I bought this and put in a gas engine, does anyone believe it would do 20 Knots and still be light enough for reasonable sailing? Those amas look like they might be solid pieces. What are the chances that they will be come water-logged and heavy and I won't be able to fix them? |
| It seems to me that it wouldn't be a good monohull or a good trimaran-at least under sail.The amas have very little to add to RM being so close to the main hull with very little freeboard that could be immersed. And the "cross arms"(struts?) would get close to waves in a hurry. I'd say pass this one up.
| The mast height is fairly low and the total sailarea not that great so i guess the amas will do fine for "normal" winds. With this boat you get the same volume as a monohull, but a little faster, less heal, and the ability to get into beaches. Maybe it "can" do 20 knots at motor, but that would take alot fuel. Dont compare it to multis, compare it to monos. /Brorsan |
| Not sure if I agree with Borsan here. If you have a look at wavepiercer cat ferries they have similarities with this design. The big difference is that the hull like bridgedeck is actually doing some flotation in this design. In regular wave piercers it is high above. There is the chance for interference drag. If there was a motor change it probably means something. So my guess is the boat's performance was not as good as designed. The biggest problem I see with using this as a cruiser is that the immersion rate of the floats will be very low. This will mean she will be very sensitive to loading. The CG is very high too. The problem of using the design concept of large wave piercers is that design rules of big boats often don't translate to smaller boats because of the square cube rule. She could be a good motor boat with sail assist with the wind aft. Don't reach with the thing in a blow. cheers Phil |
| Don't. Even. Think. About. It! |
| Well nuts. I'm still looking for that magic shallow-draft go-anywhere sailboat that can get up to 20 Knots under power when I have somewhere that I want to be. |
| Why would a mcgregor be better than this one? |
| It will have SOME resale value. |
| A 39' "downeast" influenced design - Feedback Request | dobsong | Boat Design | 62 | 09-24-2009 07:01 AM |
| Salimina - A 39' V-Bottom Cruiser by William Atkin | dobsong | Boat Design | 7 | 06-21-2009 12:54 PM |
| Trimaran Design | rapscallion | Multihulls | 27 | 02-25-2007 07:57 PM |
| Trimaran Design | BluWtrSail | Boat Design | 13 | 04-22-2005 08:46 AM |
| Package deal on 75' herrshoff and 39' finland | Tracy Blair | Marketplace | 0 | 08-11-2004 01:58 PM |
