Old 01-01-2011, 02:24 AM
Edwardn Edwardn is offline
Rep: 29 Posts: 5
20" Steel Power Catamaran
Make that 20' Steel Power Catamaran
I have seen alum power Catamarans but i havent been able to find anything in steel as of yet in the 20 foot range. I assume alum is the better choice of material but i have no experience welding it, steel is not a issue for me to work with but i also need the boat to be trailered behind a mid size suv so the weight may end up being one. I'd appreciate and info or advice on this.
EDD
Old 01-01-2011, 02:43 AM
Mr Efficiency Mr Efficiency is offline
Rep: 246 Posts: 711
Steel is heavy and cats have a goodly surface area, given that light gauges are strong enough, but don't allow room for rust losses over time, you have a minimum lower limit of practicability as regards thickness, that makes for a very heavy boat, as well as a high maintenance one. Hardly surprising they are not commonly seen in trailable sizes.
Old 01-01-2011, 03:38 AM
Rep: 29 Posts: 5
Thanks for the reply, i was wondering if weight would be a problem but i wasnt sure and i never thought about corrosion either. It looks now like if i want this type of boat i'll have to gear up for alum and learn how to weld it, i just ordered some catamaran study plans from Boden today so i'll have a look when they arrive.
too big a diesel(never at full power) and "glazing"? Squidly-Diddly Diesel Engines 23 06-01-2010 08:23 PM
Info on 33ft catamaran "RUSH" att2tude Multihulls 6 05-20-2010 05:50 AM
35' Steel "Colin Childs" refit pengreg Metal Boat Building 59 05-16-2010 07:19 PM
Can I "mix" cor 10 with mild steel plate ? globaldude Metal Boat Building 1 06-07-2008 06:03 AM
Modifty an outboard motor to power an "Iceboat"? Icefisher DIY Marinizing 4 12-14-2007 10:17 AM
