| 12- 13 ft Catamaran RIB w/hydrofoil Does anybody know of any current/active builders of this type? This is a powered dingy/tender Not a sailboat Last edited by sail4evr : 03-12-2008 at 09:05 AM. Reason: misunderstood |
| I am sure you have seen the Professor KG Hoppe's HYSUCAT concept, smallest built is around 20ft or so but as small as 12-13 ft sound like taking it too far down in size. It will of course work to some extent but I wonder for what load? |
| I don't really understand your response. I have seen hydrofoils under a chair being towed by a water ski boat. I've seen 10 ft moths, a sailboat on hydrofoils, what is different about a 13 ft boat with hydrofoils? Load should be around 900 kilos. |
| That sounds heavy ! My 24' cat is 900kg and I wouldn't like your chances of getting it up on foils. Moths are as light as a feather and sailed by scrawny fit young lads, not a craft for everyone. I think all that Nojjan is saying is its probably easier to get the numbers to work with a little more size to offset the crew load. The smaller you go the tricker that gets. |
| Thanks MB, that is somewhat clearer than my reply I guess. Yes, a 900kg square block of concrete can be made to run on hydrofoils, but under what conditions ;-), I'm sure that chair was nice and dry when they decided to stop. Any-who, if it is intended to be practical (maybe not in the scoope here) I would aim at a larger size. Note some of the findings from Hoppe, smaller HYSUCAT's are much harder to balance (LCG sensitive). But I don't want to dampen your spirit, please continue with your project. |
| So I gather that hydrofoils are not competitive in weight carrying capabilities with a traditional RIB inflatable of 13 ft (3.8m)? Many of which exist in the combined weight plus load of 900 kg. Is that right? |
| I'm talking about sailing boats, if its a power boat and you chuck enough horsepower at it and yeah I am sure its possible. Still sounds like alot of weight in a 13' craft to me, but if you say so... beyond my experience. I could not say much more than that ![]() |
| Sorry for the confuision. I'm looking for a 12.5-13 ft dingy/tender hydrofoil for my 44ft sailing catamaran There are lots of rigid bottom dingys out there with a combined weight plus payload around 900 kilos. |
| Not a CAT and not with a hydrofoil, but you may like it. Have a look at http://www.africancats.com/boten_inf.asp?boot=48 and then click on "CATALITE RIB Specs" under Specifications. Built by a sailboat maker. Have a look at http://www.duxboats.com/dux_inflatable_boats.html The dinghy http://www.duxboats.com/d300specs.html doesn't meet your payload requirements but http://www.duxboats.com/pd400specs.html has a payload of 825 kg (1820 lbs). If you're on the west coast, use http://www.duxinflatableboatsofcalifornia.com/ instead |
| Hi Steve, Thanks for the links. The dux boats are nice, but very expensive. I have seen similar at http://www.amiboats.com/Advanced%20C...I%20Boats.html maybe $2,000 less. |
| hysucat 5 mtr Hi Try Watermarque Marine Ltd on www.worldwatertaxis.com thye have teamed up with Malan Conradie and Globally market the Hysucat range now they do have a small Cat foil tender or try www.hysucatstore.com |
| Here is a picture taken of a picture in the latest Seahorse magazine. It is a 49er sailboat hull converted to an outboard hydrofoil by one of the employees at Bethwaite Design in Sydney: |
| Hydrofoil Supported Catamaran designs | malan conradie | Boat Design | 21 | 08-02-2009 04:23 AM |
| Prototype Singlehanded Hydrofoil Catamaran | Doug Lord | Multihulls | 2 | 11-01-2006 08:02 AM |
| hydrofoil | jejojoy | Propulsion | 2 | 08-24-2006 02:08 AM |
| hydrofoil | Baldur | Boat Design | 5 | 06-24-2005 11:06 AM |
| catamaran vs rib | hilux38 | Boatbuilding | 3 | 12-10-2004 09:11 AM |
