Old 10-30-2008, 08:29 PM
RickEdmonds RickEdmonds is offline
Rep: 40 Posts: 6
10m catamaran by Kevin Flower - any info?
Hi guys
I tried a search but nothing came up. I'm looking at buying a part-built (one hull) cat and finishing it off. The design is said to be "modified" by Kevin Flower (ex Flower and Adams sails I assume). The built hull looks very like a Crowther Harrier to me. The "modified" aspect may be that it's been drawn for multi-chine construction in ply. The builder of the one hull died a few years ago and along the way a lot of specifications and drawings appear to have been lost. The original drawings contemplate a "tube" cat with 3 alloy beams, or a "sport deck" version with a fabricated main beam. The original builder had drawings done for a bridgedeck version, based on the same fabricated main beam.
My major concern is whether the design will support the extra weight of the bridgedeck as I don't want to spend time and money only to end up with a transom-dragger.
Does anyone know anything about this design? It apparently dates back 20 years or so and Bob Oram built one called "Silver" in Darwin, but I was told he experimented with foils and CLR and the boat had balance problems. Interestingly enough, I suspect this is where Bob's current design ideas about submerged chines came from originally.
My concept is to emulate the open deckhouse/cockpit of the Seawind 1000 - that works brilliantly in the tropics.
Thanks for any info or comments,
Cheers
Rick
Old 11-02-2008, 04:17 AM
Rep: 700 Posts: 691
Some small help
Hello
I met the people on Silver when they came back from a Kimberley cruise in the 90s. As I recall the boat was fine but the owner was a little upset about the noise the flat bow would make in chop.
My advice is not to get a compromised project for the sake of one hull. One unfinished hull is not very far along the build process and you would probably be better served getting a modern sellable cat design like an Oram, Schionning, Woods or somesuch. The rest of the materials will cost the same on a recent design
cheers
Phil Thompson
Old 11-02-2008, 07:29 PM
Rep: 40 Posts: 6
Hi Phil
Thanks for the info on Silver. What you say makes a lot of sense, but along with the hull comes a *lot* of gear as well, which makes the purchase very attractive. The built hull is done to a good standard and all the frames for the second hull are made and ready to be erected. Most importantly, I took the wife to see it yesterday and she gave the approval - a lot more room than she was expecting, I think.
I know resale won't be as high as a recognised design, but that's far enough away not to be determinative now.
Cheers
Rick
Old 11-02-2008, 10:02 PM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
Rick, I worked with Kev at Woolwich Marina in the 80's when he was designing and advising this boat, he still lives in Sydney I believe, so contact him directly, I can give you his phone number from my old books if you send me a private message.
Old 11-03-2008, 04:35 PM
Rep: 40 Posts: 6
Hi Landlubber
That would be great, thanks. I tried to PM you but found I need to have 5 posts and then wait a day before PM is enabled. This is post No 5, so I'll be able to PM you tomorrow!
Cheers
Difference between 10m and 12m catamaran Fanie Multihulls 46 02-23-2008 08:14 PM
10m rescue rib nzrib Fiberglass and Composite Boat Building 1 11-29-2007 12:22 PM
Need Catamaran info Please! holly Multihulls 4 07-24-2007 02:03 PM
Grinding sanding dust further to make wood flower? ernie Wooden Boat Building and Restoration 27 08-27-2006 05:36 PM
Catamaran info Strykar Boatbuilding 0 11-13-2002 03:25 PM
