Go Back   Boat Design Forums > Design > Motorsailers
Old 05-17-2007, 08:14 PM
timgoz's Avatar
timgoz timgoz is offline
Rep: 262 Posts: 1,067
Small Boats for Large Folks
Hello,
I'd like your thoughts on boats that meet the following criteria. Powercraft or Motorsailors.
1. Displacement hull.
2. Enclosed wheelhouse.
3. Inboard diesel propulsion.
4. Two single berths/ settees at least 7' long. Possibly settees with 1' pullout extension(s).
5. 6'4" headroom in wheelhouse & galley.
6. Preferably steel construction with plans available for home build.
I know steel craft in the under 30' range are scarce. Any leads would be appreciated. I'm thinking of 24'-28' LOA.
Thanks.
Tim
Old 05-17-2007, 08:25 PM
Previous Member
Rep: 0 Posts: 0
ask windvang here, he and I are working on my new build and he,s in Holland,
very easy to deal with and qualified
I like the idea you are talking of,
80bhp Deere Engine, nice, let me know when you are finished, we can go fishing!
I built a boat once for some very tall men, trailer boat, somewhere in my gallery, BUT I would think abt alloy) steel!! yuk, dirty heavy
Old 05-17-2007, 08:33 PM
Previous Member
Rep: 0 Posts: 0
Originally Posted by timgoz View Post
Hello,
Thanks.
Tim
This is something he shared, just to give you an idea, but can design quickly anything you want Can dxf for cutting, so easy!!
Old 05-17-2007, 08:35 PM
timgoz's Avatar
Are you speaking of Corten? I plan on doing most of the welding myself, so I like the workability of reg. mild steel. Does the alloy you speak of weld without alot of problems?
John Deere or a Lugger (made in Alaska on J. Deere block).
I must confess, I've heard good things about your gallery, but have not checked it out. Now that I've read enough of your posts to see you are into metal boats, I think I'll take a look.
Steel has the advantage of allowing a multidude of interiour arrangements, so drawn up interiour plans are not critical, as long as I can get the berth length.
Thanks LJ
Old 05-17-2007, 08:42 PM
timgoz's Avatar
LazyJack,
Just realized you meant aluminum when you said alloy. Thought you said alloy steel.
Checked your gallery. Nice. I like the deep entry trailer boat. Whats her basic specs?
Tim
Old 05-17-2007, 08:52 PM
Previous Member
Rep: 0 Posts: 0
Thanks LJ
tim I,m talking alluminium alloy, I used to build steel, but then I woke up, now al al is cheaper than steel, thanks to China, esp with smaller boast where you use the same thickness When I say cheaper, the metal goes 2-3 times as far for the weight, you dont need to paint or blast, and its very very fast to cut and weld
needed
bandsaw
hand(skill type, like hitachi or aeg 8 inch) meataxe, (small saw on small grinder), to chase welds, and prep welds, welding plant, its so much less messy, for instance when you have a steel hull, you have it nicely painted and then Whoops you need to drill a hole,, and then you have a pile of rusty shavings on the plate,
yes you need MUCH more experience to weld al al , because a weak weld is just that, but even a poorly welded boat will hand together in Steel, With Corten you will need also could welding skill and good gear cos you will be using low hydrogen welding rods and they are not really for amatuer welders or small low open circuit welding machines .Also, forming corten is not easy, its so incredibly high ten
Old 05-17-2007, 09:05 PM
timgoz's Avatar
I plan to either take (another) welding course, had a simple one in 1990, or enlist the training help of some welding friends. Probably I will offer labor in exchange as they are not close friends. If I would go with aluminum this training would be real crucial.
Corten was never really considered as I have heard, as you said, about it being tricky to weld.
Aluminum does have a he.. of alot of advantages. From the abuse my 15' skiff, with it's thin skin, was put through, and survived, on the volcanic rock of SE Alaska, I know how tough it is.
Did like the bow on view of the red boat from gallery.
Tim
Old 05-17-2007, 09:07 PM
timgoz's Avatar
Hey LazyJack,
Out of curiousity, what time is it now down there?
TGoz
Old 05-17-2007, 09:08 PM
SAQuestor SAQuestor is offline
Rep: 88 Posts: 163
Tim,
Try drooling over the boats here, and here.
Enjoy.
Leo
P.S. for world times, go here.
You're not old until regrets replace dreams.
Old 05-17-2007, 09:26 PM
Previous Member
Rep: 0 Posts: 0
Hey LazyJack,
TGoz
1122, as you can see I,M BORED TO BITS, I,m trying learn CAD, IMPOSSIBLE for me, I built the red boat for a very keen gamefisherman, has a 230 volvo diesel, , became a friend, just died, young, yes the bow has a very good entry the entry and bottom of your boat is the most important thing Slamming must be avoided because its dwonright unpleasent, and its hard on the boat When the boat lands it must sort of feel as though the landing is cushioned Take a look at Don Sheads power yachts, they had fine entrys a boat should not have to slow its passage because of slamming, of coarse I,m not talking of extreme conditions
Old 05-17-2007, 09:32 PM
timgoz's Avatar
Thanks Leo,
Did not get to far with the Dutch site, but was able to navigate the other that included English for us single tongued people.
I assume both were from the Netherlands?
They sure know how to work steel! Drool is right.
All the construction photos could be very valuable when planning and troubleshooting.
Take care.
Tim
Old 05-17-2007, 09:40 PM
Rep: 88 Posts: 163
Thanks Leo,
Yep - Dutch folks sure build pretty boats. Just click around as there are lots of pretty pictures to be seen. Look up a free web translation service - gotta search a bit because Dutch isn't a "mainstream" European language, but they are available and just input the URL (that's the http://.... thingy) and the translation service will give a "sort of" translation. It seems that the ones I've used don't do too good with nautical terms. But good-e-nuff to get a general idea of what they are try to tell the reader.
Best,
Leo
Old 05-17-2007, 10:08 PM
timgoz's Avatar
Fishing!!!
Fishing, a magic word to me
The older I get, the more I seem to go. Not enough out of a boat where I would rather be. To paraphrase Water Rat from the Wind in the Willows.
"Ther is nothing, absolutely nothing, even half so much fun, as simply messing around in boats"
Add fish to the equation and you really got something. I do put 99%+ back.
Hope to be living in SE Alaska after boat completion. Probably truck it to Washington state and then run up the inside passage to AK. Could barge it right to water I am familiar with as an alternative.
If you can get up there (assuming my "plans" go well) I promise we'll do some seriuos fishing. Crab, shrimp, berries, and good spring water could combine with salmon or halibut for a real good feed. Beer to follow.
TGoz
Old 05-17-2007, 10:18 PM
timgoz's Avatar
One more point on fishing or "fishin" as we say.
Once had a lady refer to it as a sport.
I said it is not a sport but "a skilled pastime & if pursued correctely, a passion"
Tim
Old 05-17-2007, 10:19 PM
Previous Member
Rep: 0 Posts: 0
TGoz
Beer or Bears?
Chris was keenly into tagging but he smoked his Striped marlin, feed the whole street, you kae a lot of friends buuilding boats, but not much of the folding stuff Well where do you live now?
by way if you have doubts abt al al go www.alloyyachts.co.nz
Small passagemaking boats Greenseas2 Motorsailers 35 10-14-2011 08:54 AM
Hello folks. Looking for some advice Bill W Boat Design 2 08-17-2006 03:29 PM
Foil Assist: small or large monohulls Doug Lord Sailboats 7 12-22-2005 07:25 PM
Howdy folks Holland Open Discussion: All Things Boats & Boating 0 12-05-2004 05:39 AM
