Go Back   Boat Design Forums > Design > Motorsailers
Old 04-13-2007, 12:15 AM
northerncat northerncat is offline
Rep: 9 Posts: 170
there are a few aussie manufacturers that make assymetrics westcat are one of them
sean
Old 04-15-2007, 03:09 AM
Rep: 9 Posts: 170
heres an interesting approach to working out the hp needed for propulsion
Which engine should I use??
sean
Old 05-05-2007, 03:52 AM
Rep: 9 Posts: 170
http://members.optusnet.com.au/~rhturner1/index.html
have you considered one of these 20kn from 25 horsepower
so it can be done, id oplay around with the styling a little however
sean
Old 05-06-2007, 03:49 AM
cookiesa cookiesa is offline
Rep: 10 Posts: 65
Yeah I have, think the plans are fairly $$$ for a fairly crude design. (Especially when you compare to plans like those from Mike Waller Design.... Have the study plans for his TC670.... Power or sail ?????? (Way the fishing is at the moment I'm weaking towards the sail;!)
Old 05-06-2007, 06:39 PM
Rep: 9 Posts: 170
he reckons that his powerboat j6 gives you 18kn from a 25hp so his hull design must be alright, i would just use his hull design and build what you want up from the deck9styling is all about what you want a departure from the plans to give you this is fairly reasonable as long as you arent altering anything structural, pity theyre not assymetric otherwise id be interested, also mike wallers boat has more materials which means it will be a heavier boat plus they havent been designed for bigger outboards( not that im sure that the j6 is though)
sean
looking for economical powercat benny333 Fiberglass and Composite Boat Building 9 12-27-2006 04:13 PM
PowerCat for Passagemaking jfblouin Boat Design 4 09-26-2006 05:45 AM
5.5m powercat Alik Boat Design 1 11-09-2005 09:05 AM
7,45 powercat design vander Boat Design 4 11-24-2003 07:35 AM
unknown powercat! User_U Powerboats 6 02-21-2002 12:57 PM
