Go Back   Boat Design Forums > Design > Motorsailers
Old 05-21-2008, 01:32 AM
YuriB YuriB is offline
Rep: 15 Posts: 57
Motorsailer with pilothouse in front
Hi Folks,
i've got an old fiberglass minesweeper hull about 100ft long. The hull configuration itself is suitable for rebuilding her in to sailing vessel. While i'm collecting cash for project design, i decided to start modifying pilothouse. On the minesweepers it is located i front of the boat. I need your opinion wheither to leave it as it is in front, but lower 1 level down, which will look pretty good with sails either and take less efforts rather then build new pilot house in the aft.
Would like to listen all conns except visibility of sails-this can be resolved by glass windows in the roof.
Thanks
Old 05-22-2008, 03:22 PM
TeddyDiver's Avatar
TeddyDiver TeddyDiver is online now
Gollywobbler
Rep: 1298 Posts: 1,991
What's your plans with the boat? The most essential thing to know about a boat/ship what it's used for. Just building for fun you can make pretty much anything. Sailing with paying guests from Murmansk to Bering sea is another case..
Old 05-22-2008, 04:35 PM
charmc charmc is offline
Rep: 833 Posts: 2,390
Hi, Yuri,
Welcome to the forums. There are many experienced designers here who can advise you on the details of your conversion, but center and even forward pilothouse motorsailers are out there. Here is one example:
"The raised pilothouse is up three steps from the main salon where a center mounted helm provides excellent visibility forward and along either side. In the aft starboard corner of the pilothouse is a very large open ships' office with built-in computers, weather fax and all necessary electronics. Also, a very special feature of LA PERLA is two additional doors from the bridge. One leads directly out on to the port side of the fore deck and makes it very easy for the captain to access the deck for docking or anchoring maneuvers. The other special staircase is a half spiral in custom teak leading up to the flybridge area"
Teddy's point is important: the pilothouse location is only one factor in designing the best layout for your intended purpose. IMHO you'll need to reduce the height quite a bit, but La Perla shows that a forward pilothouse can be integrated into a well functioning and good looking vessel. Then, of course, there's Athena. Not your average motorsailer, but has a forward bridge and looks great.
Best,
Charlie
Old 05-23-2008, 01:21 AM
TeddyDiver's Avatar
Gollywobbler
Those two vessels Charm represented look great and functional. Having the superstructure "evenly" fore and aft makes the profile well balanced..
Old 05-23-2008, 05:54 AM
Rep: 15 Posts: 57
Thank you. But still there is no info how that big boats sail upwind. Probably only with engines.
The boat will be used for sailing anywere but with non paying guests)).
Regarding the height, height of the wheel house affects the ability to sail upwind, this is for sure, but at what proportion to the boat lenght? From the other hand if upwind blows towards the bow at small angle, there is just a small cross section of the hull and pilothouse resist to the wind, unlike for example,sailing halfwind. So my decision would be to leave the wheelhouse on the same place. Reducing the height by 10inch down will not probably improve upwind behavour much.
Old 05-23-2008, 06:50 AM
yipster's Avatar
yipster yipster is offline
Rep: 1027 Posts: 3,269
i like the idea of a fwd pilothouse
boat will need a keel and calculations
100 ft fiberglass or lapstrake?
eighter way, great hull, keep us updated
Old 05-23-2008, 07:47 AM
TeddyDiver's Avatar
Gollywobbler
More relevant issue than the resistant of the wheelhouse is the fact you would have your sails higher and the center of effort higher too. This reduces the sail carrying ability of the vessel and reduces the overall performance. A big boat has however more stability than smaller ones, but I would chop the second floor of wheelhouse anyway..
To your questio, yes, your boat could sail upwind. How well is much more complicated than just the wheelhouse properties..
Old 05-23-2008, 05:25 PM
Originally Posted by TeddyDiver View Post
I would chop the second floor of wheelhouse anyway. To your questio, yes, your boat could sail upwind. How well is much more complicated than just the wheelhouse properties..
I agree with Teddy on both points.
Best,
Charlie
Old 06-02-2008, 07:22 AM
Rep: 700 Posts: 3,208
Doesn't much matter , most cruisers set the sails "close enough" and seldome tinker or take in a sheet 2 or 3 inches as a racer might.
When the boat leans too much , or the sails flog , no need to look, just go trim them.
FF
Old 06-12-2008, 12:09 PM
Finlander Finlander is offline
Rep: 19 Posts: 80
YuriB, I like your sail plan. All roller furlings would be best of course.
Cons of having pilothouse in front:
you won't see what's in front of the vessel when working on deck (unless you happen to be standing on the bow); someone will always need to be inside the pilothouse keeping watch.
Pros of having pilothouse in front:
you can earn extra cash by sweeping mines
Seriously, if you are doing a major refit, with all new electronics and steering system, then maybe it would be worthwhile to consider moving the pilothouse toward the back. You can add a nice covered deck-lounge for parties...
If it's too difficult, then I'm sure it would be fine where it is now (but chopped down, as you mentioned).
Either way, it'll be quite a nice ship when completed!
Old 06-13-2008, 12:55 AM
Rep: 15 Posts: 57
Thank you all for the comments.
Sail plan is not yet finally considered as we have to calculate stability assuming that there will be no keel. I only plan to put cast iron ballast in the hull and thats it. A roller furlings this long may raise center of gravity due to their weight. There should be good combination found of the ballast weight, masts height, sail plan, etc.
Old 06-13-2008, 02:35 PM
Tad's Avatar
Tad Tad is offline
Yacht Designer
Rep: 2006 Posts: 1,639
Yuri,
Correct, everything must be considered at once as a complete system. The rig works with the hull and appendages, or not!
Below is a quick revision of the rig which will have more windage (drag) but be more versatile and easier to control/sail at optimum with a small crew.
Old 06-17-2008, 05:50 AM
Rep: 15 Posts: 57
Thanks Tad for the sail model,
3 small masts instead of 2 long ones make sense, not only due to the low point of wind pressure, but also from finacial point:conventional aluminium small yacht masts can be ordered for less price.
Old 06-17-2008, 02:06 PM
Tad's Avatar
Tad Tad is offline
Yacht Designer
Yuri,
Steel pipe may also make some sense for masts, depending on various other factors.
Old 06-22-2008, 06:33 AM
With a vessel that was never designed to sail , the concept of a very small engine assist while beating might make sense.
The gen set should produce a bit of thrust , if rigged right , so could be charging the battset and helping a non sailing hull to sail a bit.
FF
Pilothouse window design darr Wooden Boat Building and Restoration 7 08-08-2007 08:48 PM
Pilothouse Spray questions Finlander Boat Design 0 08-19-2006 09:28 AM
Pilothouse Question searaytuna Fiberglass and Composite Boat Building 0 12-23-2005 03:18 AM
cockpit or pilothouse EASI54 Boat Design 17 09-05-2005 06:23 PM
Pilothouse Sailboat Design Guest Boat Design 0 06-13-2003 11:03 PM
