Go Back   Boat Design Forums > Design > Motorsailers
Old 10-23-2010, 07:50 AM
gunship gunship is offline
Rep: 137 Posts: 146
The motorsailer: Not good at anything or just a motorboat with sail?
commonly, motorsailors seem to be regarded as either a bad compromise or as a motorboat with a mast. i cannot really understand why this would have to be the case.
For a few years, my family had a motorsailor. the motorboat with a mast type - as it had no keel. many people i know had sailors with an inboard engine, but no pilothouse.
commonly the thing that conflicts between motor vessels and sailors are the Keel and the pilothouse, and some hull shape differences. but if youre not planning on excessive speeds, is the hull shape really such a decisive factor? i understand that an ideal motor vessel would have a hull designed to fit with the propeller, which would decrease sailing performance. would a waterjet be a solution?
(following is some gobbledeygook that the casual can skip)
layout wise, the pilothouse is a problem. the motorsailer we had had a pilothouse halfway lowered, and a hatch, so if you stood at the helm, you would be standing up through the roof. i found that a pretty good sollution, maybe not ideal, but very functional. the problem was the cockpit, that was nonexistant. on my philosophical sketches (As in just theorycrafted) i placed the cockpit practically on deck level behind the pilothouse. while not providing quite as good protection against the seas, i figured in a storm you always have the pilothouse. the cockpid i sketched was lowered a little, so that youre clear of the boom when standing, and you could see over the pilothouse.
If someone bothered following me on that, what do you think?
is there any other ovious problems with a motorsailor?
Old 10-23-2010, 08:31 AM
apex1
There are many, many motorsailor threads already here. You most probably find all the answers just by using the Forum search function.
Regards
Richard
Old 10-23-2010, 09:39 AM
Fanie's Avatar
Fanie Fanie is offline
Fanie
Rep: 2057 Posts: 4,291
Hello Gunship !
Yes, there are lots of problems with motor sailors ! The first is mine is not finished
The problems there are are mostly between the ears. The power boat guys think sailboats are these slow sluggish things. The sailies think power boats are for a rough group of speed monsters (like Richard )
Most sailboats are actually motor sailors in any case, since they all have a motor for windless times. When you go to larger (than small) boats they usually have displacement hulls, these have a design speed for the hull that is mostly considered the max speed. Thing is you can go faster than hull speed with enough power applied.
Personally I like the idea of going places for free (for a change), so sailing suits me. There are times however I would like to use the motor's instead.
So imo nothing wrong with the extra option.
Regards
Fanie
Water ! Just gimme water !
Old 10-23-2010, 11:44 AM
apex1
speed monsters yeah?
57 ft. Passagemaker / Trawler for sale.
Old 10-23-2010, 11:57 AM
Fanie's Avatar
Fanie
Sure. Just look at the boat you sell. From my little boat that's a MONSTER
Maybe you should sell it in meters ?
17m sounds a lot more moderate than 57ft, unless you want to charge more for it.
Regards
Fanie
Old 10-23-2010, 12:29 PM
Rep: 3125 Posts: 9,399
There are good and bad motorsailors, just like choices for a wife. Actually, I think you have better odds at the good wife.
As in any other yacht design selection process, you have to make lists (many) of the things you need and desire in a yacht. Eventually, the prioritizing of these lists will focus the candidates into a small enough group where a few will stand out and the selection made.
Then again you can build a semi or full out custom. Naturally this is a bigger investment in everything, but not so unusual an issue. Lastly would be finding a good candidate, but rearranging her accommodations to better suit you. This is likely the most economical option, especially with the wide open market to choose from.
Old 10-23-2010, 12:50 PM
pool pool is offline
Rep: 38 Posts: 47
It's not that difficult to have a good motorsailer:
Take a proven, more traditional (metal) sailboat hull with sufficient integral tankage. Something along the lines of a Jongert or Nordia that, with a furling rig, will sail reasonably well in trade wind conditions.
Then add a reliable single diesel and a variable pitch prop that can load the engine for motor sailing, and be set to min. resistance when sailing.
Hey presto - there's a decent motorsailer!
Old 10-23-2010, 01:06 PM
apex1
Good idea!
So my 22 meter Passagemaker should be a Monster bargain at 2 mio.
Old 10-23-2010, 06:09 PM
Fanie's Avatar
Fanie
Eeessshhh Par, I can see how impressed any woman candidate will be if you make lists to evaluate her
Richard, 57ft is 22m ??? My calculator must be broken...
Regards
Fanie
Old 10-23-2010, 08:43 PM
Had you made lists of the qualities and needs you required in a wife, how many times would you have had to eat alone?
Old 10-24-2010, 10:29 AM
apex1
Of course.
To make the boat not look too monstruos we make it 57 ft. and to earn a few pennies we sell it at 22 m.
Old 10-26-2010, 06:10 AM
Rep: 1493 Posts: 7,447
With the new lightweight powerful engines available, the so called saiboats are really motorsailors. They used to be called auxiliaries, but now they do maximum design speed under sail or power, the definition of a motorsailor.
Old 10-26-2010, 09:11 PM
Willallison's Avatar
Rep: 2319 Posts: 3,502
My favourite motorsailer...
http://www.superyachttimes.com/edito...rticle/id/3697
Will
Imaginocean Yacht Design
www.imaginocean.net
Old 10-26-2010, 10:25 PM
I'm more of a Marco Polo fan, though the lifeboat hull form could use revision for aesthetic reasons.
Old 10-26-2010, 10:52 PM
Brian@BNE Brian@BNE is offline
Rep: 140 Posts: 222
Ok, but they won't have long range under power alone will they, unless quite large to fit the tankage required?
Yes Will, a good choice as a favorite. Very nice indeed!
Turning a motorboat into a motorsailer :-) rickinnocal Motorsailers 28 01-26-2011 12:32 AM
Restauration 21ft (6,5m) motorboat etxee Projects & Proposals 2 01-21-2009 07:10 PM
New hull design for motorboat YG.Archi.nav Projects & Proposals 1 12-10-2008 03:26 PM
Jetboat Motorboat construction HusH74 Boat Design 1 02-11-2008 07:33 PM
Looking for motorboat info??????? MarioCoccon Powerboats 2 05-25-2006 05:47 PM
