Go Back   Boat Design Forums > Design > Motorsailers
  #211
Old 07-17-2007, 12:38 AM
brian eiland's Avatar
Rep: 1503 Posts: 2,647
I can see where it would aid in damping roll, but not that much in extra driving power
  #212
Old 07-17-2007, 12:59 AM
Guillermo's Avatar
Ingeniero Naval
Rep: 2041 Posts: 3,567
Yeap. Not that much, but pretty good for my really undercanvassed boat.
Guillermo Gefaell
Moon Yacht Design
  #213
Old 07-17-2007, 05:12 AM
Rep: 1623 Posts: 2,343
Guillermo, Brian
Here's a picture of the vessel romping along in the trades, I can see the extra knot here. The topsails an old gaffer flies are not so dissimilar , just getting as much up as possible in good clean air.
This mule is a bit bigger in proportion to Marie's and cut for the job
Mike Johns.
  #214
Old 07-17-2007, 05:39 AM
Pericles's Avatar
Pericles Pericles is offline
Rep: 1040 Posts: 1,645
Ok,
Thank you all very much for the informative replies. However, I am still mystified as to the name for the triangular sails on Glamare 300 set above the jib shaped staysails. Or are they also called mules? Whatever they are, I like them.
http://www.marigraph.com/gallery.php...&num=01&lng=en
Regards,
Pericles
  #215
Old 07-17-2007, 12:10 PM
Dear Pericles,
Is that a computer rendering, or an actual photo? The sails just look too perfectly set?
  #216
Old 07-18-2007, 05:03 AM
Pericles's Avatar
Brian,
The vessel exists only on a hard drive, but, what a vessel!
BTW, what's the name for the triangular sails set above the staysails?
Regards,
Pericles
  #217
Old 07-18-2007, 03:58 PM
Guillermo's Avatar
Ingeniero Naval
Perry,
I think those are called 'trysails' in english (not storm trysails, but mast trysails), but I'm not sure.
Were quite common in schooners and even in steamers.
Cheers.
Guillermo Gefaell
Moon Yacht Design
  #218
Old 07-18-2007, 04:53 PM
Pericles's Avatar
Guillermo,
Trysails! Of course! I think I may have known that, but the old brain box is sometimes faulty on recall. I was going to call them "Leg of Mutton" sails, because of their shape.
Thanks for that.
Pericles
  #219
Old 09-13-2007, 09:13 PM
RHP's Avatar
RHP RHP is offline
Rep: 1073 Posts: 568
A trysail was certainly the storm'sl abaft the mast working in combination with the storms'l on the forestay on a sloop, I cant say whether the same name applied to the full size working sail pictured. Really she's a wishbone schooner without the wishbone by the look of it thanks to modern materials and technology.
  #220
Old 09-14-2007, 01:15 AM
MacLear boomless cutter
MacLear & Harris designed a boomless cutter build by Palmer Johnson I believe. It was a vessel in the range of 80-90 feet
Does anyone have, or know where I might find a photo or two of her??
Frank Maclear was a big fan, and a pioneer of boomless sailing rigs
RunningTideYachts.com
Distinctive Expedition Yachts
  #221
Old 09-14-2007, 04:59 AM
Brian
She was called Falcon II.
LOA 62' LWL 50' 5" Beam 16' 3" Draft 8' Displ 92,000 lb SA 1823 sq ft Built in Aluminium by Palmer Johnson for B Heineman of Chicago.
All sails are roller furling, the Canadian designer Simpson had a similar design both seem to have performed very well .
Cheers
Mike Johns.
  #222
Old 09-14-2007, 10:07 AM
Angantyr
Thanks Mike, I wasn't aware of that one.
I remember a big strong looking cutter called "Angantyr" that was built for a gentlman here on the Chesapeake Bay. But it had a boom. It also had twin tandem centerboards.
I believe there was a larger version of this design built as a boomless vessel, wherein the mainsail was sheeted to the three backstays??
  #223
Old 09-14-2007, 07:09 PM
I know Angantyr very well and viewed her recently with a view to purchase, she was on the hard in an industrial area in Houston and she'd been half gutted, the rudder had been extended most horribly and the teak decks had been glassed over.
The nav station was perched in an annex half way up the companionway and she was a bit dark down below, so I wisely but reluctantly passed her by.
I'm aware of a smaller version but not a larger one.
Mike Johns.
  #224
Old 09-14-2007, 07:27 PM
MacLear cutters
I posted these MacLear designs today
http://boatdesign.net/forums/showpos...1&postcount=64
http://boatdesign.net/forums/showpos...3&postcount=65
  #225
Old 09-14-2007, 08:53 PM
RHP's Avatar
RHP RHP is offline
What a beautiful yacht, thanks for posting. I have previously tried to find a website dedicated to MacLear and Harris but couldnt find anything. Is there a site i've missed or a book of designs at all?
Mike, where did you find Angantyr, any web reference?
Cheers
Richard
