| foam the stringers I need to know if it would be acceptable to inject urethane foam into the stringers after the compression areas were fixed with epoxy or wood, all of my stringers are good, no cracks, but the wood in 80% gone, this is on a motorsailer and the hull is thick |
| If the wood is 80% gone the stringers are not good. If you fill them with wood, there should be no voids to inject foam into.
__________________ Gonzo |
If you tell us how old the boat is, what size, what condition, etc., it might be possible for folks here to come up with other solutions. But right now, we can't be sure whether you're talking about one bad stringer or 20 of them. Nor do we know whether it's just a bad part here or there or if the whole boat is shot. The lack of specifity, no doubt, is at least partly responsible for the dearth of responses. Also, try using the search function as this seems to be a pretty common problem and I know it's been discussed many times before.
__________________ Are we off-topic yet? |
| Bedding Stringers | man5 | Fiberglass and Composite Boat Building | 2 | 04-14-2006 07:35 PM |
| stringers | Boat Craze | Materials | 2 | 03-17-2006 11:57 AM |
| Wet foam stringers | don1113 | Materials | 4 | 08-09-2005 06:24 PM |
| Stringers in, now the floor | Ok J | Fiberglass and Composite Boat Building | 2 | 06-23-2005 01:10 PM |
| Encapsulating stringers | Ok J | Fiberglass and Composite Boat Building | 17 | 04-30-2005 10:18 AM |
