| Furling Square Sails Quote:
| 'Dyna Cat' Press Release I received a rather nice press release in an up-scale yachting publication just recently Dyna Cat |
| compliments, thats a very very good article did you see the rough ladybird pdf i made? okay inspired but many paralel thoughts ![]() |
| Yipster, Great Ladybug PDF. Hope you build it one day. I like concept - I wonder how concept could be adapted to a large monohull ... How much sail is needed to move a 70 footer that weights 70,000 at 7-9 knots. |
| thanks mydauphin, ehr.. think others here can answer that question better and faster but did order marchaj's books. forexample procyon has a strikable bipod. like making some schetches to see what aspects of concept to alter and have some L/B and deck dimensions. |
| Congratulations, Brian, that's a nice writeup. Hopefully good for business!
__________________ Best, Charlie |
| Beautiful design, Yipster. Hope you get the funds to build it!
#25
| Dynarig sloop In one of the Yachting World articles about Maltese Falcon was a detailed explanation by Gerard Dijkstra about why the Dynarig is not suited for a sloop configuration. As far as i can remember the main reason was the the inability to trim lateral sail balance. |
#26
| eh, ah, that my ladybird can, reefing in stages tho this beeing the intruded thread this idea got up why not a short animation ![]() Last edited by yipster : 01-26-2008 at 09:28 AM. Reason: work in progress |
#27
| SeaSpark, Have searched Yachting World for article about Maltese Falcon, but cannot find it. Could you post more information please? Pericles |
#28
| An interesting comparison between specially rigged proa and catamaran models. http://www.youtube.com/watch?v=s-AzmNEj0EE Pericles |
#29
| Pericles, try these mate, she is one hell of a yacht. http://www.ybw.com/auto/newsdesk/200...951ywnews.html http://www.yachtingworld.com/yw/supersail/falcon.html http://www.ybw.com/yw/blog/200609081...vid_glenn.html http://www.yachtforums.com/forums/pe...ing-yacht.html
#30
| LandLubber, She's a real beaut! More years ago than I care to remember, I learned about a square rigged topsail gaffer schooner that used a pulley system to deploy the rectangular sail, outwards from the foremast, on rings sliding along the upper and lower spars. I've been thinking it was Joshua Slocum's design, but I can't be sure. The sail could be set or reefed in seconds, like pulling curtains. With a bit of tweaking it would not be too difficult to emulate the Dyna Rig by laminating the spars from marine ply and epoxy, to create a 12 degree arc and then rigging the sails, top and bottom in sail tracks. A bit of muscle power on inhaul and outhaul sheets, passing down to the deck from the outer ends of all the spars and which are then cleated off, would position the rotating mast for upwind work. A car disc brake at the base of the mast would lock things quite securely. This square rig system is only suited for broad beam fast catamarans, as Brian Eiland has so effectively demonstrated, because although the mast rotates, it is still supported by very widely positioned stays. OK, so there are a few more ropes, but we are sailors after all. It's what we do, haul 'em up, reef 'em in. Also, I must have a mainbrace to splice and a yard arm for hanging pirates. Avast behind, me hearties! Pericles |
| Maltese Falcon ... hit or miss? | Stephen Ditmore | Sailboats | 308 | 09-30-2011 09:24 AM |
| Maltese Falcon | Guillermo | Sailboats | 2 | 03-31-2010 08:51 AM |
| Maltese Falcon Web Site | tom perkins | Sailboats | 8 | 09-16-2009 03:56 PM |
| Sloop verse Square Rig, Maltese Falcon vs Mirabella | brian eiland | Sailboats | 28 | 06-10-2007 11:13 PM |
| deriveur integral (internal ballast sailboat, ala: alubat, feeling..etc) | samh | Sailboats | 2 | 08-24-2004 01:32 AM |
