Old 12-12-2011, 08:01 PM
Outboard Dave's Avatar
Outboard Dave Outboard Dave is offline
Rep: 36 Posts: 13
Where are all the little guys?
You som gums are jest to smart for fellas like me. I have red your posts and have come to garl-dern conclusion you fellers are way to smart for me. Talk about some fancy posts. You guys have the market cornered there. It hurts my brain reading these posts.
If your a little guy like me and love restoring old aluminum boats, post back.
This is like being lost in a whirl wind.
Just saying......
The "Orignial" Embarrassment to the entire boating community.
1957 Feather Craft Ranger II, 1957 Lone Star Nassau.
Old 12-13-2011, 12:14 AM
Rep: 3125 Posts: 9,399
Do you have a question little fella?
Old 12-13-2011, 05:49 AM
Rep: 36 Posts: 13
Well, I thought I knew a lot about boats untill I stumbled onto this site. Then, I read, read and read some more.
Is everyone on this site a master ship builder?
Dont get me wrong, I will continue to read and learn but, hokie smokes, you guys are a smart crowd. I feel like a Zebra running with a herd of Quarter Horses.
Kinda like being back in school.
Post Script:
Is there really such a thing as day/night cycles for aluminum stress?
Old 12-13-2011, 06:05 AM
Ad Hoc Ad Hoc is offline
Naval Architect
Rep: 1933 Posts: 3,025
Originally Posted by Outboard Dave View Post
Post Script: Is there really such a thing as day/night cycles for aluminum stress?
Konichiwa Dave
If you're referring to thermal stresses created by the difference between night and day, the day time having the heat of the sun on the ally, then yes. This linaer expansion can exacerbate a flaw in the structure. Aluminium, in case you're interested, the thermal conductivity is 244W/mK for the temperature range 0~100°C. Additionally, for the common commercially used wrought aluminium alloys the coefficient of expansion varies from 23.5x10-6 /K for the 4.6% Cu aluminium alloy and to 24.5x10-6 for the 4.5% Mg aluminium alloy. In plain language, it is twice that of steel.
Old 12-13-2011, 06:45 AM
Rep: 36 Posts: 13
So, what your saying is Aluminum is stong but heating/cooling will cause a crack to "run"?
Did I get that right?
Old 12-13-2011, 07:24 AM
Rep: 670 Posts: 2,457
Aluminium certainly moves when heated. Ask any welder.
On a hot day, the proximity sensor that signals DOWN position on my retractable bow thruster fires off daily because of the movement of the dark blue hull. Its also very difficult to keep paint on the sheer clamp joint...too much movement and the paint film breaks at the blue white transition
Old 12-13-2011, 07:57 AM
hoytedow's Avatar
hoytedow hoytedow is offline
Resistor
Rep: 1871 Posts: 3,357
Here's a classic ring and ball experiment to illustrate how much metal expands thermally.
http://www.youtube.com/watch?v=hX2Y2IDjuGI
P.S. I'm in your category(one of the little guys). Some of these posts make my head spin too.
Hoyt
Old 12-13-2011, 10:45 AM
Submarine Tom's Avatar
Mariner
Rep: 937 Posts: 1,941
And some are just plain ridiculous.
-Tom
Old 12-13-2011, 11:49 AM
lewisboats's Avatar
Obsessed Member
Rep: 1263 Posts: 1,841
Does that work with chemical HEET 'cause I sure could use.....
Steve Lewis
Lewisboatworks
http://angelfire.com/ego/lewisboatworks
Old 12-13-2011, 11:53 AM
OFFSHORE GINGER OFFSHORE GINGER is offline
Rep: 39 Posts: 20
-Tom
I agree 100 % .
Old 12-13-2011, 12:22 PM
hoytedow's Avatar
Resistor
-Tom
Especially mine.
Hoyt
Old 12-13-2011, 05:00 PM
Naval Architect
If the heat/cooling cycle is continuous or frequent, and the crack or flaw, is pre-existing, then yes. The constant expansion and contraction will induce a strain cycle into the structure. This also assume that some part of the structure is restrained, or held.
If you have a sheet of aluminium with a hole/crack in the centre, and it is simply supported on its lower edges, then the whole plate will expand and then contract uniformly. If you clamp one edge, then you are introducing a "stiffness" to the plate, that prevents a uniform expansion. That shall gives rise to internal non-uniform strains, and act as the driving force for crack propagation.
Old 12-13-2011, 05:33 PM
daiquiri's Avatar
Engineering and Design
Rep: 2574 Posts: 2,731
And to give an idea about what it means for the structure, take a case of a 1 meter (3.3 ft) long aluminum-alloy bar constrained at it's ends. If it is heated from 15° to 60° C (a not uncommon situation in areas where sun is hot during the day and the night sky is clear), you get a 45 °C (or 45 K) thermal excursion.
It means that, if the bar were not constrained, it's length would vary during a 24-hour period by 24.5x10-6 x 45 = 1.08x10^-3 meters, or 1.08 mm.
But the bar is constrained, so there are counteracting loads on it's ends, and their intensity is such to keep the bar's length unchanged.
Since elongation (strain) and stress are related by the equation stress = E x strain (where E is the Young's modulus, equal to 70 GPa for aluminum), it follows that the (thermally induced) stress due to constraints will be as high as 70x10^9 x 1.08x10^-3 = 75 MPa.
If the bar was made of 5086-O alloy, which has a yield strength equal to 130 MPa, it would be loaded to 58% of it's yield stress just due to this thermal expansion/contraction, which adds to eventual other mechanical loads acting on the bar.
Though a case of a bar rigidly restrained on both ends is not so common, it gives a clear idea about how fatigue carves it's way after a sufficiently big number of comparable cyclical thermal+mechanical loads on the structure during the years of service.
Cheers
Old 12-13-2011, 06:31 PM
Poida Poida is offline
Rep: 395 Posts: 1,072
And now comes the rediculous post.
It is common for people with aluminium dinghys to turn them upside down on the beach.
Because the sun is heating up the shell of the craft and the bracing inside the boat is in the shade (because it is inside the boat) wouldn't expand to the same degree.
Does this make the problem worse?
Poida
Old 12-13-2011, 06:37 PM
hoytedow's Avatar
Resistor
It shouldn't be too problematic because metal conducts heat as well as it conducts electricity. Inside bracing would increase temp and expand just due to contact with hot outer surface.
Hoyt
I need your help guys,,,,,,, Capt Rick Materials 3 09-23-2007 07:45 PM
to can you guys help me? i need help!!!! Sailboats 4 02-16-2006 05:24 AM
thanks guys dionysis Open Discussion: All Things Boats & Boating 0 08-01-2003 04:17 AM
Hey guys - need your help eightwgt Boat Design 10 04-20-2003 09:25 AM
