Old 11-05-2008, 05:56 PM
philgib philgib is offline
Rep: 10 Posts: 20
What would cost such a "aquarium" barge ?
Thanks to MarshMat and MikeJohn for their input
This is for a special use but with a very basic shape :
- Constant 30 inches draft for underwater windows (I will take care of the windows)
- 5.85 meters long at the top
- 5.20 meters long at the bottom
- 2.30 m high
- All made in 6mm
- Strong top structure so that a few people could walk on it without the metal to bow.
- Bow at the front (instead of the vertical flat showing on this drawing)
- The 2 sides must be rigid enough to stand the important pressure of a 30 inches cm draft.
- My understanding is that the displacement would be about 13 m3. Would a 12 cm steel sheet welded inside the barge as a layer on the completely flat bottom be enough to act as a good keel and weigh enough on the boat to maintain the 30 inches draft ? Could anything cheaper than steel be used ?
- Completely empty inside (structure should be right below the very top or inside the bottom keel
Dimensions are such that the barge can fit into a 20' container and can be sent to me.
Would any of you have an idea of approximate weight and building price ?
Of course PMs are welcome.
Thanks a lot
Philippe
Old 11-06-2008, 10:01 AM
Rep: 10 Posts: 20
Goal is to obtain my little design :
I have never designed a floating boat before. Does that one makes sense ?
CMD "project Zeus" VS VOLVO "IPS" gerard baladi Propulsion 13 09-10-2007 10:23 PM
Boat "workshop" including a "testing tank" zmfmd Open Discussion 0 08-08-2007 05:43 AM
"Free" 3D modeler "similar" to Rhino CGN Software 0 05-14-2006 11:56 PM
CNC made "plug" or mold, cost and finish Raggi_Thor Fiberglass and Composite Boat Building 3 03-09-2006 04:26 PM
Drawing for Rhino of "Boat Racing Chair" and "Machine Gun" Vibtor Software 0 10-02-2004 03:03 PM
