| What size motor? 40" steel I have a 40 foot steel hull sailboat. It is a rounded hull 3.6 wide. Draft about 6 feet What rpm would a sailboat motor be recommended to run @ High torc low revs say 1500 rpm? Also if I was to have an auxilliary motor how would a 75 hp outboard be? |
| 45 to 54HP would do the trick...
| Thanks heaps. I make biofuel from used cooking oil and there is a percentage of the fuel that needs to be heated in order to use it. I want to run a generator with it. Most descent generators that last are designed to run around 1500 rpm. Is that compatable with the boat because the hp is compatable for the size generator i need. Them when I'm ready and the boat is nearly finished I can put the generator motor in the boat. |
| RPM's on engine Gensets run 1500-1800 rpm's often to meet the Htz. For your boat without much more information I would say a Yanmar 3JH4 or a 4JH4. Yanmars are biodiesel compatable along with Cummins. Cummins is in the biodiesel powered Earthrace, but they don't make small yacht engines. |
| Nice, i googled both models. Thanks for that. |
| Hermann Görings Motor Yacht "CARIN II" rotting away in the Red Sea | Metronicity | Open Discussion: All Things Boats & Boating | 55 | 05-14-2008 04:17 PM |
| Modifty an outboard motor to power an "Iceboat"? | Icefisher | DIY Marinizing | 4 | 12-14-2007 11:17 AM |
| How do you determine motor size | lee@simmtechs.c | Propulsion | 6 | 11-22-2005 03:48 PM |
| out board motor well size? | rickc | Boatbuilding | 2 | 06-24-2002 10:23 AM |
