| What should I use for welding Aluminum? Tig or Mig? All things being equal which one gives you the strongest welds? |
| Assuming the welder is competent, tig will give you a better weld - but it's very, very slow compared to mig. I'm using my next project to justify buying a tig machine, although if I were planning a commercial venture I'd opt for a good mig machine with a spool gun.
__________________ Stonebreaker Ph.D in Redneck Engineering - Piling it higher and Deeper. |
| MM250/30A spoolmatic Mig is much cheaper, easier to learn, and FAST. Miller's Millermatic 250 with a 30A spoolgun is as good as you can get without going broke. They also offer a spoolmate gun for a few hundred less, but it's a little dinky and less versatile. It works well, but it's a lesser product. Come to think of it, the Millermatic 210 might be able to run either gun(definitely runs the spoolmate gun) and is $500 cheaper, but with the MM250/30-A setup, you can stick a mixed gas bottle on the welder and leave it set up for steel, then run an argon hose along your power cord, around the left or bottom side of the 250, and to the spoolgun. Both setups are always set up and can be selected by the flip of a switch. I used one like this for a while, and there really aren't any weak points. It will work as well as anything else on the market, and anything better probably can't be touched for twice the price. _____________ Lance |
| Currently I am running a 350 miller XMT with 30 A spoolgun works very nice. Dan |
| It kind of depends on what you are planning on doing. As peviously posted a Tig will give you the strogerweld and a beautiful finish if you know what your doing but it should be reserved for the shorter bead projects. I know exactly what Stonebreaker is talking about. I bought a small Lincoln 175 square wave tig for my personal enjoyment trying to justify this to my first mate that I needed it for a job I was working on. Great for doing thinwall aluminum pipe. The joints look like they were formed. But to do some production welding involving long beads in an aluminum boat refit had to use a spoolgun. |
| The only thing you need TIG for is high stress applications, like BMX race and freestyle frames, or stainless high pressure apps ie hydraulic lift cylinders. but MIG has to be done right, or you can end up with a piece of junk. I used to be a commercial welder and I was tested on every TIG weld I did. |
| TIG vs MIG The tig and mig welding processes are two different techniques developed to address different situations encountered when welding. It's all about control. The TIG process allowes the operator to start and sustain an arc and thus a puddle of molten metal without introducing filler metal into the point of weld which gives the operator more control over the rate of travel. Additionally with the TIG process an arc can be started "hot" and then turned down using a finger control or foot pedal while welding, this really helps when trying to weld thin materials-1/8 inch or less aluminum without blowing holes for example. With the Mig process the filler wire is used as the electrode that creates the arc and the molten puddle so the operator has to deposit filler metal to weld=less control. This is not a problem when attemting to weld thicker material but makes it virtually impossible to weld something like a beer can with a mig setup. Pulse mig is a process that strives to have it both ways by rapidly cycling the electrical pulses of a mig welding machine. This allows the operator to weld both thick and thin mat. R |
| Aluminium Welding | daedong | Metal Boat Building | 4 | 06-05-2006 05:16 PM |
| MIG welding .080 5052 aluminum sheet | Jack D Davis | Metal Boat Building | 2 | 09-26-2005 10:07 PM |
| Welding aluminium. | ted655 | Materials | 20 | 01-22-2005 11:34 AM |
| New to welding Aluminum | captain butch | Metal Boat Building | 22 | 11-28-2004 08:35 AM |
| Welding Speed for Aluminum Hulls | jprev | Metal Boat Building | 3 | 11-06-2004 09:31 PM |
