Old 08-16-2008, 03:17 PM
alumboat10 alumboat10 is offline
Rep: 10 Posts: 3
What filler to use on 5052 Aluminum
What are your thoughts on what filler wire to use for Mig welding 5052 1/4" Sheet Aluminum. This would be a butt weld on seams on the bottom of the boat. I worry About corrosion. 4043 or 5356?
Old 08-16-2008, 05:32 PM
lazeyjack
5356 on all marine applications and not to put too fine a point on it, but so as you know, a seam in never a butt, a butt runs across the boat a seam along and above 1/8 we say plate not sheet, what are you building?
you should add pms to your profile, I dont mind helping that way
Old 08-16-2008, 06:32 PM
Rep: 10 Posts: 3
thanks for the input. We are building a flat bottom barge and we have used 4 x 10 1/4" plates for the bottom. it is 10' wide x 36' long. I want to make sure we have a good seal. The framework is all 6061 and we have been using 5356 to weld. We were debating on using 4043 or 5356 to weld the plate butt welds on the bottom of the boat.
Old 08-16-2008, 08:25 PM
lazeyjack
they are very different and electrolysis can start. great fun welding in barge is it not?
what sort power pack and gun are you using
Old 08-16-2008, 08:52 PM
Rep: 10 Posts: 3
We have a Lincoln Power MIG 350MP with the python gun.
Old 08-16-2008, 10:21 PM
lazeyjack
is that an assist like the cobra was or a true pulling gun? like the hobat linear was?
Aluminum 5086 or 5052 plate? DanAyo Materials 7 01-24-2009 06:07 AM
6061 or 5052 ? ted655 Metal Boat Building 2 03-22-2008 03:42 PM
wanted: 5052 aluminum sheet .25" pabble Marketplace 0 06-14-2007 09:59 AM
aluminum hulls+marine filler=issues gforcepdx Sailboats 3 11-19-2006 11:16 PM
MIG welding .080 5052 aluminum sheet Jack D Davis Metal Boat Building 2 09-26-2005 09:07 PM
