  #121
Old 09-22-2008, 04:05 PM
Previous Member
Rep: 0 Posts: 0
Originally Posted by bigbear69 View Post
just wondering if you are able to weld deck fittings/ repair work while the boat is on the water? Or will the current associated with welding cause electrolysis or something?
cheers
no problem at all, all ships are finished(usually) in the water
  #122
Old 09-24-2008, 03:58 PM
Member
Rep: -33 Posts: 951
I did almost all the detailing on my current boat in the water. No problem.
You can easily hook up an alternator run off your main engine if you want to do it out in some peaceful ,remote anchorage. I'd do it that way next time.
Tom , if you get the chance , go ahead and post the photos from the back cover of my book on this site.
Thanks
Brent
  #123
Old 10-17-2008, 10:40 PM
Previous Member
Rep: 0 Posts: 0
you can see the cleats across the seam, the seam gap is 4mm, no vee, then a ceramic temp backing bar which is in segmants slides under the cleats and is wedged up
Advantages, , single sided welding, almost no grinding from outside
i have not tried on ally, but have used same method with steel or ss backing bar with groove in it,
  #124
Old 10-18-2008, 02:28 PM
Member
Rep: -33 Posts: 951
I've seen photos from Norwegian shipyards ,of welders on tracks that fill a V while a ceramic brick slides up while the weld is still molten , leaving a smooth surface behind, flush with the surounding metal, needing no grinding whatever.
Maybe ceramic backing is underutilised.
Brent
  #125
Old 11-02-2008, 12:02 PM
welder/fitter welder/fitter is offline
Rep: 423 Posts: 407
Ceramic backing strips have a value & are utilized within the marine vessel construction & repair industry, though less in North America than in Asia or Europe. For the one-off builder, the cost would be the limiting factor. In this regard, perhaps, there would be a real value in ceramic strips when wishing to weld both sides of a joint that is relatively inaccessible from one side.
Quality joint preparation is crucial to welding proficiently with ceramics. For those members who wish to experiment with ceramics, I suggest that, when welding, keep the arc in the puddle, "wash" the puddle from side to side & use a lower current or wire speed. While ceramics can handle greater temperatures than the parent metal, they do not have the same capacity to conduct electricity and can be pushed from the parent metal by the force of the wire.
Mike
  #126
Old 11-02-2008, 03:12 PM
Previous Member
Rep: 0 Posts: 0
in that case mike your backup is not right, under those cleats is a 3/8 flat bar, dogged to the ceramic full length,
the rest is ok)9/10
  #127
Old 11-03-2008, 08:47 PM
Rep: 423 Posts: 407
LOL
Sorry Stu, I was actually commenting on ceramics in general. Still, 90%
(9/10) isn't a bad mark for something I didn't study! The ceramics we use have metal "stickum" across the back to hold them in place. They are prone to dropping off - a flat bar backing, any kind of backing, that could be dogged against the ceramic strip, holding it to the seam, seems like a good idea, though I can already hear the complaints about it taking too long to set up.
  #128
Old 11-03-2008, 09:55 PM
Previous Member
Rep: 0 Posts: 0
Originally Posted by welder/fitter View Post
LOL
HOW MANY TIME Si HAVE TO TELL YOU BUGGERS, NO SHORT Cuts in boatbuildin' 3/10)
  #129
Old 11-13-2008, 06:57 PM
Member
Rep: -33 Posts: 951
Only damned fool would look for the long cut.
Brent
  #130
Old 11-15-2008, 08:59 AM
tazmann tazmann is offline
Rep: 192 Posts: 217
Glad I didnt chime in on the ceramic strips, not knowing anything about them I would be in the minus LOL.
Noticed Lazzy got banned, is that permanent or just for a time?
Tom
  #131
Old 11-16-2008, 12:00 AM
Landlubber's Avatar
Rep: 1491 Posts: 2,449
Lazy is too good to be permanently banned, he was just sent to the corner to think for a while
  #132
Old 11-21-2008, 07:07 PM
Rep: 192 Posts: 217
Ok thanks, was hoping it was not permanent.
Tom
  #133
Old 11-22-2008, 03:04 PM
Member
Rep: -33 Posts: 951
I't would appear to a bad economic decision to hire someone to build a boat , who advocates finding the longest and most tedious way to build a boat and who opposes inovation.
Brent
  #134
Member
Rep: -33 Posts: 951
I't would appear to be a bad economic decision to hire someone to build a boat , who advocates finding the longest and most tedious way to build a boat and who opposes inovation.
Brent
  #135
Old 12-17-2008, 03:45 AM
Guest62110524 Guest62110524 is offline
Previous Member
Rep: 0 Posts: 0
http://store.cyberweld.com/mirwife.html
can anybody recommend this feeder please)
Steel Welding query JimCooper Metal Boat Building 23 08-13-2009 03:46 AM
Steel Hull Survey. GerH Metal Boat Building 7 06-23-2008 03:49 PM
Welding Astm316 Stainless Steel tevhit Boat Design 2 11-02-2007 02:17 AM
Welding stainless steel hazards SamSam Metal Boat Building 0 11-28-2006 07:10 PM
welding steel plate on a keel lockd Metal Boat Building 4 11-10-2005 06:50 AM
