Old 08-21-2009, 02:01 AM
tightfits tightfits is offline
Hotwelds Tightfits
Rep: 33 Posts: 7
welding on negative pressure
While trying to seal up an airtight aluminum hull I discovered that hooking a vacume to the fitting used for air testing while zapping a persistant leak was very effective. Is this a common method?
Old 08-21-2009, 10:17 PM
kmorin kmorin is offline
Rep: 230 Posts: 185
Vacuum Techniques
tightfits,
yep that's the easiest way to keep the [heated] air inside from expanding into the weld zone and perpetrating the porosity/leak problem- pull a vacuum.
Its just as easy to do with a cold wet rag, though. The cooling of an area of plate will usually cause the void to suck in air and all it takes is enough 'inflow' to pull some molten puddle in to freeze in the void, then close out the weld on top and most decks seal.
cheers,
kmorin
welding on negative pressure tightfits Boatbuilding 2 08-27-2009 06:52 PM
Negative Bows ? Canada Bob Boat Design 23 04-27-2009 02:06 PM
negative drag in flex gliding gull? lunatic Boat Design 0 06-06-2008 11:05 PM
Open Discussion – Negative Framing Sean Herron Boat Design 6 11-18-2007 07:40 PM
Why not give hulls 'negative camber' on a cat? Ward Sailboats 8 06-14-2003 04:19 AM
