Old 03-02-2005, 12:02 PM
Hammersmith Hammersmith is offline
Rep: 10 Posts: 3
Welding Iron
My 105 year old dutch barge 'Gideon' is in dry dock, where I'm going to add a 10 feet section of hull and topsides. Anyone got experience of welding old mallable iron? I'd prefer mig, as I'm quite used to it (I'm the set engineer on Junkyard War) but I have heard that I should use flux cored wire and reverse polarity. I've done some spark tests, they look the same as new steel in length and colour.
regards
Richard Curtis
mv Gideon
Hammersmith, London
Old 03-04-2005, 03:54 AM
Rep: 1623 Posts: 2,343
Many of the so called irons of this age are in fact steel. A grinder spark test on iron will give a very different result to a mild carbon steel and to a high carbon steel. So if your spark tests are the same then weld with your mig as for steel.
You can test simply by trying to weld a bit of mild steel bar end on to the hull plate then try tapping it off, if its iron it will fall off with the first blow, if steel you'll need to cut it off with a disk.
Hope this helps
Mike Johns.
Old 03-04-2005, 02:37 PM
Rep: 66 Posts: 640
Richard,
Contact one of the following, I think they have some experience with old Dutch barges:
http://www.oranjewerf.com/Index.htm
http://www.shipdock.nl/frameset.php?mid=61
Dutch Peter
Old 04-25-2005, 01:43 PM
Rep: 10 Posts: 3
Thanks Mike and Pete, the hull turned out to be high quality 100 year old Groningen steel. I cut with a plasma and welded with my mig and Gideon is 90% back together. Because of the sheer line on my tjalk I had to slice the bow horizontaly just under the rubbing strake and raise it 150mm, and now the new steel is in, the lines look perfect. I've taken a few photo's, what's the best way of posting them for you fellows to see?
Richard
MV Gideon
Hammersmith, London.
Cast Iron Swing Keel Repair...Need Tips! Guest Sailboats 12 09-26-2010 11:21 PM
MIG welding .080 5052 aluminum sheet Jack D Davis Metal Boat Building 2 09-26-2005 10:07 PM
time to replace the iron keel with lead but... tranmkp Sailboats 2 02-08-2005 04:28 PM
welding aluminium captain butch Boatbuilding 9 12-31-2004 03:21 AM
Replacing an iron keel with a lead keel. Kris-Stockholm Boatbuilding 4 06-21-2004 01:45 PM
