Old 01-14-2010, 07:34 PM
alloy sailor alloy sailor is offline
Rep: 10 Posts: 3
welding aluminum/minimal gear
I am a good fitter and fabricator with many different materials. I have done some welding. I want to build solid lifelines for my aluminum sailboat and do some other projects. I need something to tack the parts together and I will hire a pro to finish weld everything. Can this be done with a 110 power supply; maybe a 140 mig with a spool gun I found some good deals on craigslist.
Old 01-15-2010, 12:25 AM
welder/fitter welder/fitter is offline
Rep: 423 Posts: 407
I'd suggest making stanchions/horizontals from stainless with ss base plates insulated from, but through-bolted to aluminum doubler plates, using stainless fasteners.
All of this aside, for tacking purposes, the 140 mig will do it, no problem.
Mike
Old 01-15-2010, 01:38 AM
Rep: 10 Posts: 3
I like stainless but the boat came with a pile of aluminum pipe for this reason; I could sell it and buy stainless but why would it be better. I see aluminum rails on commercial and recreational fishing boats and looks good and seems strong enough.
Old 01-15-2010, 04:51 PM
Rep: 423 Posts: 407
That you, Jay?
I've replaced aluminum lifelines & handrails on a few vessels, usually bent badly, but once with tears at the bases, just above the support bracket welds. Always replaced with ss. When I bought one of my boats, the Al dodger frame was a real mess & I've seen others that haven't held up very well. So, mark it all down to personal preference, if you will. Btw, very nice modern-style ph! Brilliant move!
Mike
Welding aluminum with a MIG smithmiller6 Metal Boat Building 3 02-02-2010 09:37 AM
Need some advice on welding aluminum. bntii Metal Boat Building 5 07-10-2009 06:47 PM
Aluminum, welding equipment. Tigrik Metal Boat Building 23 03-04-2009 04:10 AM
What should I use for welding Aluminum? CKP Metal Boat Building 6 03-03-2007 12:53 PM
New to welding Aluminum captain butch Metal Boat Building 22 11-28-2004 07:35 AM
