| Unfolding formed boat panels to flat sheet Hello all, I'm interested to know if anyone knows of a CAD package (hopefully not too expensive) which would allow me to model the finished boat (aluminium run-about) and then unfold into flat panels for CNC machining. I would like a solids modeller, or something that would plug into a solids modeller to allow me to manage my bill of materials etc. I am currently looking at Solid Works and a Rhino add-in called Expander. Is anyone using either of these, or have you investigated them in the past? Thankyou and best regards, Rohan |
| Many high end CAD packages have sheetmetal design attachments that can do this, you could also look at Pro-Engineer and Ideas (both around £5000), although I use both of these packages I have never used them for sheetmetal work so I cannot comment on how good they are. I am sure the resellers would be only to willing to give you a demo! |
so: Prosurf+Rhino+ Expander + (Solidworks, Pro-E, Solid Edge or even IronCad)+Any 2D cAD Solidworks + SurfaceWorks+Flatten (Plate development form Surfaceworks) I like the first one becosue i use Prosurf for my hull design, and then send it to rhino to tweak it if i need to, and add decks and more, even renderings and so on, then i will create the surfaces for Expander and save this surfaces of the hull as rhino and open them in Solidworks, and thats all, ready to go on with the rest of the structural details. the fisrt one seems a long shot but price is good and you get all theh right tools to go on, the diference between the firts one and the second one is that you don't have a flexible solidmodeler like rhino that can wokr with all this software and render your models, no need of flamingo, just BMRT an rhinoman works like a charm good luck |
| Thankyou Thankyou for the suggestions, they were very helpful. I'll follow them up and let you know how I get on. Cheers, Rohan |
| Hull speed | Mike D | Boat Design | 33 | 02-27-2011 02:20 AM |
| Auto engine marinization | DIY Marinizing | 231 | 07-01-2010 08:34 PM | |
| 18 ft Flat Bottom Boat Molds | sharkeymarine | Marketplace | 5 | 07-07-2003 08:47 PM |
| geometry of sailing | Sailboats | 8 | 10-12-2002 11:58 AM | |
