Old 02-27-2007, 08:40 PM
LAURASDAD LAURASDAD is offline
Rep: 10 Posts: 4
Transom Brace Weld
Hello,
I am a newbie so forgive me if this is the wrong forum. I just bougt an aluminum bass boat. There is a brace on the inside of the transom. The brace's weld has failed where it meets the floor.
Is this a major issue? I had a welder look at it and he said it wouldn't take a weld. It was previously welded and whatever they previously used was preventing a new weld from taking.
thanks for any advise
Larry
Old 02-27-2007, 09:28 PM
charmc charmc is offline
Rep: 833 Posts: 2,390
Welcome
Larry,
Welcome to the forum. Any guy who signs himself as his daughter's dad must be a good guy!
In a former life, when I ran a small equipment rebuilding shop, we once had a bad crack in a vacuum pump casting repaired successfully by braizing, so I know it might work.
This company says their braizing rod is an advance over what we used 15-20 years ago. I don't know this company's product from personal experience, but they say the rod will work on aluminum repairs when conventional welding will not. Maybe it will work for your boat; there is a lot of info available to evaluate it, and they sell a kit for under $100.
http://www.aluminumrepair.com/index.asp
I hope it works out for you.
Good luck,
Charlie
Old 02-28-2007, 06:16 AM
sal's Dad sal's Dad is offline
Atkin/Bolger fan
Rep: 80 Posts: 109
I have to agree...
Old 02-28-2007, 09:53 AM
Originally Posted by sal's Dad View Post
I have to agree...
That's great!
(Full disclosure, I'm Erin's Dad)
Old 02-28-2007, 11:49 AM
timgoz's Avatar
timgoz timgoz is offline
Rep: 262 Posts: 1,067
Sounds like this might have been caused by repetetive stress, in which case just welding it might result in a short-lived repair. Consider beefing up the immeidiete surrounding area. A backing plate opposite the brace or insetting a slightly heavier piece of aluminum hull into an appropriatly cut out area might work.
TGoz
Old 02-28-2007, 02:37 PM
Rep: 696 Posts: 1,232
Consult another welder.
Old 02-28-2007, 04:16 PM
Rep: 10 Posts: 4
Thanks
Thanks for your replies. I am going to bring it to another welder. I thought maybe they could weld some angle aluminum around the brace. This would give them a clean surface and give some additional support.
thanks again
Larry
Old 02-28-2007, 09:23 PM
SaltOntheBrain SaltOntheBrain is offline
Rep: 66 Posts: 80
Dirt Eater and Fire Breather.....
At you service!!
Did Aluminum boat repairs for a living for years, and I'd bet some genius put JB Weld on it. I don't blame the guy for not wanting to do it, but it needs to be done and that's what he gets paid to do.
A little heat and a stainless cup brush on a small grinder will usually clean up that kind of mess. If it's in a tight corner, a stainless toothbrush may be required, or even a knotted die grinder brush. Again, in stainless.
Aluminum will not weld properly or at all if it's not clean. And be very careful what you touch it with especially if it's going to be in salt water. Steel bristles, Brass bristles, pencil marks(They're graphite, a nobler metal), dirty grinding discs. They can all contaminate the aluminum and cause galvanic corrosion.
Aluminum is a woman. Beautiful, sexy, smart, and will break your heart if you handle it improperly.
I'll tell you everything useful I know about Aluminum boat repairs if you need to know more. P.M. me, send pics, call me(806) 438-5494.
I really hate to see a bad repair job. You also need to address why it broke in the first place. If you just weld it back, it will probably break again regardless of the quality of the weld. It will likely need to be welded, smoothed off and reinforced.
Is it a riveted or a welded boat? Riveted boats are often so thin they are difficult to weld, so ordering a new bracket, drilling out the old rivets and bucking in the new ones is often a better fix.
Does any of this help you?
__________
Lance
Old 03-01-2007, 10:23 AM
Rep: 10 Posts: 4
Weld Repair
Thanks very much for your replies, they have been very helpful. I am taking the boat to another welder who comes highly reccomended.
I thought maybe they could use some angle aluminum on the bottom where the weld failed. They could weld this new piece onto the brace, and it should give them a clean service on the bottom to "re-weld" since it will move the weld area over a few inches. I think it makes sense for me to add some reinforcement.
By the way, it is a welded boat
Do you think the welder will have some insight as to how to add the reinforcement? thanks again
Larry
transom soundness grady Sterndrives 3 11-27-2006 09:32 AM
Weld or Bolt Richard & Diane Metal Boat Building 4 08-30-2006 08:30 PM
transom shelbygone Boatbuilding 10 07-08-2006 07:10 PM
transom bammy the bass Fiberglass and Composite Boat Building 1 09-27-2004 06:03 PM
Give me 5minutes and I can teach a monkey to weld rOx-Weld Boat Design 0 02-07-2004 04:20 PM
