Old 01-14-2006, 04:38 PM
safewalrus's Avatar
Ancient Marriner
Rep: 659 Posts: 4,759
You could always glue it! See thread this section! we're looking for volunteers
Old 01-22-2006, 01:58 AM
MRRPM MRRPM is offline
Rep: 10 Posts: 8
tHIS QUESTION IS NOT THAT DIFFICULT.
It all depends on where and what you are doing. Tig can be used on thick sections with the right gases and a trail gas. You can also use tig in the dcst
setting only when the material is very clean.
Mig can be used in the same way on thick and thin.
1. where are you using it. is it production appearance, strength, both.
2. Some times I tack sections with tig then do a full penn with mig. Now what about the alloy that you are welding. The filler wire will make a differance. gas coverage. are you in the elements or are you in a shop where there is no wind or obstructions to mess with you.
To get a better under standing of aluminum check out my web sight in the auto and boat section most of the boat was welded with mig as it was hot and durty aluminum. no water tight areas only a few. the sealing of the water tight area around the engine was water tight first pass with tig then three stringers with mig. Ut ok it wasn't easy.
www.mrrpmwelding.net
Robert
Welders ?!? (Aluminum) DHN Boatbuilding 89 07-20-2009 09:37 PM
MIG welding .080 5052 aluminum sheet Jack D Davis Metal Boat Building 2 09-26-2005 10:07 PM
mig rico Marketplace 0 04-30-2005 03:01 AM
First time MIG user captain butch Materials 1 10-14-2004 01:00 PM
